no i have not. will any of this stuff show a code with a scanner. and i have been trying the search button to find scanner codas and cant remember where it is. thanks
No in my experience it doesnt throw a code unless it is the "fuel pressure too high or too low" (or something like that) which seems too common to base anything off of. If you put a scanner on it it has a small description of the code. You can go to the "live data" tab, or something like that, and select which options you want to watch and watch it while going down the road. Or have a buddy watch it. If it has something to do with injectors you can select injector pressure or duty cycle. There are a lot of different options to choose from. That is how I narrowed problems down in my buddies truck. The codes really didnt do me any good.
