Gas tank Issue
Old Aug 23, 2011 | 02:25 PM
webfranklin's Avatar
webfranklin
Gas tank Issue
Twice now when my 2004 f250 shortbed got just below 1/4 tank of diesel it stalled out like it was out of fuel. Last night i added 2 gallons of fuel after this happen and it started right up no problem. At first i was thinking ok the fuel gauge is off by 1/4 tank but then last night after putting in 1-2 gallons to make it to the gas station it only took 22 gals to fill it up and it should have taken at least 27 gallons. What are the possible issues that wouls cause this?
Old Aug 23, 2011 | 03:59 PM
U.P. Builder's Avatar
U.P. Builder
There was a thread here yesterday with the same issue. All I could think of was that the fuel pickup tube had an issue, like a hole, or crack or something that was 1/4 tank off the bottom.
Old Aug 24, 2011 | 12:40 PM
TheBestKindOfEX's Avatar
TheBestKindOfEX
Downhill no go
If the fuel level in my 6.0 Excursion gets to that point I have to be careful to NOT park with the front end lower than the rear. It will starve it every time.
Even driving along and coming to a stop downhill will cause the fuel pressure to drop. If I stay too long it will die!
So when you get that low only stop in level, or uphill spots.....crazy!!!!
Old Aug 24, 2011 | 02:19 PM
webfranklin
gas tank
I was on flat ground I live in houston tx lol
Old Aug 24, 2011 | 02:42 PM
TheBestKindOfEX
I'm sorry....... ;o)
Old Aug 24, 2011 | 03:22 PM
dchamberlain's Avatar
dchamberlain
Read this thread. It's a lot of work to drop the tank and check, but it could be the problem.
https://www.ford-trucks.com/forums/8...d-for-3-a.html
Phobia16V
36
Jan 18, 2021 04:01 PM
4.9LOldFordTruck
13
Mar 2, 2016 11:56 PM
samcage
Jun 22, 2011 11:58 PM
AndysFords
Sep 22, 2008 02:20 AM
77GTLB
2004 - 2008 F150
Aug 8, 2005 12:46 PM
