need help reading codes
Old Aug 22, 2011 | 01:15 PM
mikerans's Avatar
mikerans
hi there, i have a 95 f150 XL and i need my codes to be read. im having tranny problems and i heard that the E40D tranny is electric, so it might be a sensor that's the problem. i took it to advance, but wouldn't you know it, there scanner isn't compatible with a 95 or older. so im having a buddy do it, does anyone know where the hook up might be for the scanner..?
Old Aug 22, 2011 | 01:28 PM
hoss khaos's Avatar
hoss khaos
You actually don't need a code reader. There's a cheap one you can buy, or you can use a small jumper wire or even a paper clip. The codes flash out from the Check Engine Light. Here's a link that describes how to do it. Ford Fuel Injection » How To Run a Self-Test
Old Aug 22, 2011 | 01:45 PM
mikerans's Avatar
mikerans
thats awsome! i think i might even have a light tester. so i understand HOW to do it..but how will that tell me if one of my sensors is bad? forgive my ignorance, im 16 and this is my first truck
Old Aug 22, 2011 | 02:13 PM
White 97 xlt's Avatar
White 97 xlt
Just post up the DTC codes you get.. Someone will tell what they mean or point you to someone who can...
Good luck with it....
Old Aug 22, 2011 | 02:19 PM
Lazy K's Avatar
Lazy K
Ford Fuel Injection » 3 Digit Self-test Codes 111-171 Compare the codes you get to this list (from the same site that hk gave you).
You don`t need to wire in a test light if you check engine light is working as it will flash out the codes.
BocceMon
27
Nov 11, 2014 08:39 PM
manasota
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 13, 2005 08:47 AM
justbabs
Nov 21, 2004 11:06 AM
acerockola77
Dec 18, 2003 12:40 AM
95BlackF150
20
Sep 20, 2003 06:08 AM
