Lost a wheel
Old Aug 21, 2011 | 09:36 PM
Hammily's Avatar
Hammily
Lost a wheel
My friend has a 2002 Excursion, came back from camping today and lost the rear passenger tire on the Highway. All eight wheel studs broke clean off. No one was hurt and the damage is minimal, but no idea why it happened.
Old Aug 21, 2011 | 10:00 PM
wpnaes's Avatar
wpnaes
The last guy who rotated the tires forgot to tighten the lug nuts? Once a little loose, they'll break off pretty easily under the weight of the Ex and torque of the engine. Glad he safely got off the road.
Old Aug 22, 2011 | 07:07 AM
perryg114's Avatar
perryg114
This is exactly the reason I always take loose wheels to the tire shop. Granted the Excursion wheels are heavy to deal with. This is also a good time to check brake pad wear and front end components.
Perry
Old Aug 22, 2011 | 10:26 AM
jasoncw's Avatar
jasoncw
Huh? You have your wheels come loose often?
Old Aug 22, 2011 | 11:17 AM
perryg114's Avatar
perryg114
No, but I have heard of it happening and I have had ruined lug bolts from shop monkies over tightening with impact wrenches. With alloy rims do you really want some kid with a week's work of experience tightening the lug bolts on a several hundred dollar rim not to mention what could happen if the wheel does come off? I doubt the outcome of the rear tire comming off would have been very good if it had been a front tire or if they were towing when it happened. You also reduce the risk they are going to bend the frame or put a jack where it should not have been. I have seen several small car where shop monkies just put a jack under the floor pan and bent it all to heck. The same goes for changing oil. I have known several folks who have had the oil plug leak because it was not tightened and one that was overfilled so bad it shot oil out everywhere. Like all service industries it is based on what you can get away with and still make money.
Perry
Old Aug 22, 2011 | 11:52 AM
jasoncw's Avatar
jasoncw
Oh, I totally understand that. I interpreted your statement to mean that you will go to the tire shop if you have a loose wheel. I agree those torque sticks are crap. I always watch them to make sure they use a torque wrench. If not, I tighten them up myself at home.
Old Aug 22, 2011 | 03:19 PM
gmcbride's Avatar
gmcbride
Are they stock wheels or after market? If after market were they hub centric? The studs on these were not design to carry the load an X can handle? Just a thought...
Old Aug 22, 2011 | 03:21 PM
jasonodsky's Avatar
jasonodsky
Glad your friend was alright!
I forgot to torque mine on the X. (trying to finish up front end work on a cold dark night) and over time the rim rattled around on there. It slowly elongated the stud holes and slowly wore away at the studs. The only symptom was a little vibration.
Standing in a parking lot, I noticed a lug nut looked loose and to my suprise the studs were half worn away. I drove it home the 3 miles, pulled the hub and pressed in new studs that night. YIKES
Old Aug 23, 2011 | 06:43 PM
Hammily's Avatar
Hammily
They are after market rims. I think I know what hub centric is, but I have not looked at them to verify what they are.
Old Aug 23, 2011 | 06:53 PM
njneer1's Avatar
njneer1
Starts with a little squeak...you can hear at stop signs and lights...snaps them right off...glad nobody got hurt !
Old Aug 23, 2011 | 08:23 PM
EXv10's Avatar
EXv10
More lugs break off fromm being too tight than being too loose. They will usually give you some kind of warning before they break from being too loose.
Old Aug 23, 2011 | 09:05 PM
njneer1's Avatar
njneer1
Is that statistcal data ? Or opinion ?
Old Aug 23, 2011 | 09:17 PM
Snowseeker's Avatar
Snowseeker
Anti-seize will cause over torque leading to broken studs. 90% of the studs I have replaced in my life had anti-sieze on them.
Old Aug 23, 2011 | 09:56 PM
EXv10's Avatar
EXv10
It's from my 50 years experience of working on and around vehicles. Do you have any data?...................I didn't think so.
Old Aug 23, 2011 | 10:44 PM
Hammily's Avatar
Hammily
I am planning to help him fix it. Does anyone know if the rear studs can be replaced without removing the hub?
