Lost a wheel
Old Aug 24, 2011 | 07:22 AM
Hammily's Avatar
Hammily
I think we will try freezing the studs and see if we can get them in that way without removing the hub. I ll let you know if it works.
Old Aug 24, 2011 | 07:31 AM
2006lariat's Avatar
2006lariat
If you can get them in the hub, put a spacer or washer's on them and suck them in with the lug nutz. Than check too make sure they are seated.
Old Aug 24, 2011 | 08:34 AM
Snowseeker's Avatar
Snowseeker
Use a spare lug nut to pull the stud in and throw it away when finished. Moly lube works great to keep the threads in perfect condition while pulling the studs in with nuts as well.
Old Aug 24, 2011 | 10:20 PM
Hammily's Avatar
Hammily
Wheel studs are too long we will have to remove the hub.
Rob89
Apr 9, 2018 09:19 PM
cpoer
Oct 16, 2014 08:39 AM
John51
Feb 15, 2006 03:04 PM
laynrubber
May 14, 2004 09:38 AM
Black Mack
Jul 24, 2003 09:11 AM
