how in the hell????
Old Aug 21, 2011 | 01:05 AM
PstrokeN's Avatar
PstrokeN
how in the hell????
ok guys i got my turbo to install on my 99 which my old one whent to **** so i go and think ok 35mins to take off id say an hr to go back no it took me 2hrs and i couldnt seem to get the up pipe to go on the exhaust on the turbo how do you guys do it i put it on there first then had to pry it so the two bolt holes lined up which im pretty sure messed the two o rings on the pedastol up and now leaks oil like a mo fo so if anyone could help me, bolt turbo down then how do i get the up pipe and exhaust housing to bolt up thanks!!!!
Old Aug 21, 2011 | 01:51 AM
Bonanza35's Avatar
Bonanza35
I've never done it but i've read that they keep the up pipes loose to bolt the thing to the turbo and after doing so then tighten the up pipes. I wouldn't think you would have to do this for a new turbo only but someone will tune in shortly. Chet
Old Aug 21, 2011 | 06:14 AM
bobbyrjw's Avatar
bobbyrjw
Loosen the up-pipes at the manifolds
You have to loosen the uppies at the manifold.
Put the turbo on correctly, torque it correctly, and NEVER pry on the pedestal.
Align the baby's butt, put on the clamp, and then tighten the uppies at the manifold.
I missed the alignment part the last time I pulled my turbo. It will sound awful.
Old Aug 21, 2011 | 07:16 AM
Calli's Avatar
Calli
I've never had problem with up pipes moving out of position upon removal of turbo but down pipe is another story. I put jack under truck/exhaust pipe and use slight pressure to raise downpipe approx. 1/4 inch. Then on top, I stuff rags at the side to hold downpipe against turbo. It would be nice to have 4 hands or another person and you could avoid this. If the alignment is not correct, those clamps are a bear.
Old Aug 21, 2011 | 08:37 AM
timmyboy76's Avatar
timmyboy76
Yeah, i've removed mine, 3-times so far and yet to have loosen the uppies. Its a PITA, but i wouldnt go prying on anything
Old Aug 21, 2011 | 09:56 AM
PstrokeN's Avatar
PstrokeN
yea my turbo had some mean turbo bark i got the exhaust on easy but the up pipe i couldnt get to line up and those bolts on the uppies are nasty and didnt wanna come loose.
Old Aug 21, 2011 | 11:39 AM
CSIPSD's Avatar
CSIPSD
I am assuming your not putting a Late 99 turbo on a Early 99 truck???
Otherwise you just have to play with it... Turbo swaps are easy so long as you hit everything with PB Blaster a day or two before. And when I say everything, I mean damn near the whole turbo.
Old Aug 21, 2011 | 01:01 PM
PstrokeN's Avatar
PstrokeN
thanks guys since i pryed the whole turbo to line up with the uppies and this morning i took all aprt again the upper o rings on pedastol were not leaking so i took it off and replaced bottom o rings shes good to go!!!! and it lined up prefect! this turbo is a early 99 turbo with the warm up thingy takin out and when i shift gears it barks loud is that why the exhaust back pressure plate delete???
Old Aug 21, 2011 | 01:20 PM
Calli's Avatar
Calli
Don't know that anything should be barking, etc???
Old Aug 21, 2011 | 05:15 PM
PstrokeN's Avatar
PstrokeN
lol turbo bark
well you know when a trucks pullin like at a truck pull and u let off throttle it barks, well this kinda sounds like that but its coming out the exhaust so i dont think its the turbo pushing air back out the compresser side which isnt good for ue turbo
MudhenGIB
Jul 3, 2010 02:54 PM
1957F100
Mar 28, 2009 10:28 PM
IDPisan
26
Jun 9, 2007 02:47 PM
redneckboy
Mar 30, 2007 11:32 AM
bloomy63
Sep 3, 2006 02:45 PM
