re:1995 ford explorer rubbing sound when braking
Old Aug 20, 2011 | 06:51 PM
ford4.0's Avatar
ford4.0
I have a 1995 ford explorer that when I brake it sound like rubber rubbing and gets worse when I turn right I am think I have a warped rotor but there is no shaking in the steering or anything but it does pull to the right and I can hear like a baby bird chirping on the right side also so please somebody help me I replace the left caliper cause it was going bad and I am thinking that I need to replace all the rotors and the other caliper also please I am baffled
Old Aug 21, 2011 | 11:14 AM
armeddoc's Avatar
armeddoc
Try jacking the truck up and turning the wheel while its off the ground to rule out the bearing. Had a similar prob with a pick-up.
Old Aug 21, 2011 | 07:07 PM
aquanaut20's Avatar
aquanaut20
Warped rotor would pulsate the pedal. Chirping indicates the wear limit on pads.. Philip
Old Aug 22, 2011 | 12:48 AM
ford4.0's Avatar
ford4.0
re:pads are new
The pads are new and I have no pulsating in the pedal I was told bearing or cv shaft making a rubber or rubbing noisse
07ExplorerXLT
Nov 2, 2010 10:45 PM
XLnAK
Aug 20, 2008 09:45 PM
boxcar1974
Jul 17, 2008 05:05 PM
boris
Jun 9, 2005 11:17 AM
websthes
Mar 12, 2002 12:24 AM
