Compression Testing Question
Old Aug 20, 2011 | 09:36 AM
Argess's Avatar
Argess
My FE experience has been limited to solid lifters, but I have a question.
When performing a compression check on a hyd lifter engine, can the lifters bleed down enough (during cranking) that by the time you get to the last few cylinders, the cylinder pressure becomes significantly lower?
If so, it might be yet another good reason for doing leak-down tests instead.
Old Aug 20, 2011 | 11:57 PM
Hypoid's Avatar
Hypoid
The short answer is no.
If you are cranking, you should be pumping oil.
Old Sep 3, 2011 | 11:16 PM
neon tony's Avatar
neon tony
leakdown will miss valvetrain probs like flat cam lobe or bent pushrod.
Alaska11
May 30, 2019 12:34 PM
cyclone-429
Jan 30, 2015 04:39 PM
Mickyblue
17
Nov 25, 2011 11:20 PM
66flareside
Mar 8, 2006 10:25 AM
HawgDawg
Feb 13, 2005 11:26 PM
