Emeregency Engine only running on 4 cylinders
Ok I am at my camp 2hrs from home and yesterday morning i took it down to the store and everything was good. came out of the store went to start truck and it was idleing really bad. drove it back to camp really slow. Only about a mile. start diagnosing and find out i am not getting any power to the injectors on drivers side. pulled whole wiring harness apart and nothing. tested for continuity for injector wires from the plug that connects to vc to the pin on the main harness by the fuse box and it was good. I had my brother bring me a pcm and idm from a buddies truck that runs and it didnt do anything. I also tested volts while cranking and on the pass side i had 2.5v on both plugs and 0v on the drivers side. I checked all fuses and tried swapping relays around and no change. I am at a loss here guys really dont want to have it towed 130 miles.
Any help would be greatly appreciated
Thank you, Shaun
Thank you, Shaun
Most likely an under valve cover harness is burned
On each valve cover connection there are five pins. The outermost pins (pins 1 & 5) are for the glowplugs. They should not have continuity with each other or the center three. The center three are for two of the injectors in each bank. The ohm reading between each outermost injector(pins 2 & 4) and the center pin (pin 3) should be about 3.2 ohms (if I remember correctly. Pins 2 & 4 should also not have continuity with each other.
Ohm your injector solenoids at the VC plugs. See if any of the wiring going to the injectors reads too high or open. A bad injector solenoid can cause the IDM to shut down the entire bank. The bad solenoid I've seen only read about 1/2 an ohm different from all the good ones, but it was enough to shut down an entire bank. A new injector fixed it up.
Checking solenoid ohms:
Check at the solenoid.
Cross leads of multimeter, mine reads 0.4, yours may be something else.
Check ohms, mine will read 2.9 - 3.1. Any lower than 2.9 and the solenoid is usually bad.
If you cross leads and start with, say 0.0, then the lowest good reading you should see would be 2.5.
Make sense?
Good luck.
Make sense?
Good luck.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Make sense?
Good luck.
Make sense?
Good luck.
Thanks jim
Ok just ohm tested all injectors with the tester on 200 when i cross the leads it reads .3 and all injectors read 3.0. so i am going to assume they are all good. I didnt check them right at the solenoid because i would have to remove them. is it still accurate checking from vc plugs ? Any other ideas for things to check? Is there anything under the dashboard that can cause no power to the injectors on drivers side. Glow plugs have power just not the injectors.
Have you done anything else to the truck lately? Anything seem unimportant or not related you're not telling us? We're either missing a piece to the puzzle, you tested something wrong, or we're down to testing the wiring between the PCM and IDM.
When you checked the wiring between the valve covers and IDM, how did you do it?
Also I checked it by unplugging the main harness and seeing if I had continuity between the main plug pin and the plug for the vc.
