Sponsored by: Real Truck
2003 Rim Offset/backspace
Old Aug 19, 2011 | 10:44 PM
TXHillCountry's Avatar
TXHillCountry
Hi all, looking at replacing my stock KR 16" rims with some Moto Metal 951s. Probably 18x9 to keep some sidewall, but I also looked at a set of 20x9 that looked nice.
In any case, can someone remind me of the proper backspace and offset I want to go with for the 2003?
Many thanks in advance!
TX
Old Aug 19, 2011 | 11:49 PM
SoCalSuperDuty03's Avatar
SoCalSuperDuty03
The 8x170, 18x9 951's used to be available in only one backspacing, not sure if that changed, haven't had any for a while. You can call them direct in California for info 714-892-2210.
Old Aug 20, 2011 | 10:14 AM
cartmanea's Avatar
cartmanea
Stock offset is +6mm for that year. How wide of a tire are you using? Anything more negative than -6mm will stick out past the fender slightly with a 12.5" tire. If you're staying with a 285 or so, then you could go up to about -19 to keep them flush.
moedaddy
Jun 30, 2012 09:11 PM
78'fordtruckguy
Dec 19, 2010 07:13 PM
pipefitter73
Oct 5, 2009 03:44 PM
Todd316
Dec 11, 2008 12:01 PM
MP1
Dec 17, 2004 12:44 PM
