Sponsored by: Auxito
Tranny Problems!!!!!!!
Old Aug 22, 2011 | 10:28 PM
Bluegrass 7's Avatar
Bluegrass 7
.......It looks like youve narrowed it down to an open power lead from the fuse location to the case motor.
.......That explains why it stopped in the position you found it in and stuck in 4L.
.......I don't have the color codes for your model year.
.......Best to inspect the plug good for a contact issue and follow the harness back as far as you can for anything that might have happened.
.......Look at all the lead color codes and see wich one might feed the motor. Perhaps an Ohmmeter check on a lead to ground that appear to be an open circuit is the one your after.
......Then at the fuse box try to match the same color code.
......At that point see if there is voltage after the fuse.
......If yes the lead is open toward the case motor.
......If no voltage on the lead, the fuse holder has a problem.
......As a test, feed a 12 volt source to the motor lead with eveything in place and try out the 4x4 functions.
......If they work decide what you will do the effect a fix.
......Always fuse a new lead for safety.
......In these circuits, all the hardware is feed voltage through fuses.
......To operate the hardware, grounds are switched, not power leads, in nearly all cases.
......I think your good testing has pin-pointed it very well.
Good luck.
Old Aug 22, 2011 | 10:59 PM
tofer76's Avatar
tofer76
problem with that is the wires to the motor go up into the cab and then i cant find them again
and to me i seem to have a problem with the electical and vacuum systems
or is one not alowing the other to function?
oh and both fuse boxes only go to 32 i think i have no higher numbers unless there is some hidden that i havent found
Old Aug 23, 2011 | 12:06 PM
Bluegrass 7
I went to the Motorcraft website and looked up your model/ year.
You have quite a different fuse layout from a regular F150.
However, it looks like fuse 17, engine bay, is the one you should look at for a power issue to the transfer case motor.
Get some way to check for power at the fuse supply side to see if there is an issue at that point, then look toward the motor side and make checks for being open.
Good luck.
Old Aug 23, 2011 | 09:26 PM
tofer76's Avatar
tofer76
well i took the dash apart to get to the transfer case relay and then i did some diagnosis on it with it plugged in and i jump pin 8 to ground it clicks and rotates the motor one direction
if i then ground pin 9 it then clicks and rotates the motor the other direction
sooo from all the other info i have gathered and read it is sounding like the GEM might be bad
however seeing as my t case motor is really rusty and rough looking and a few wires are getting worn and it is cheaper than a GEM i will replace this weekend
then some more test before i search for a gem
Old Aug 23, 2011 | 10:38 PM
Bluegrass 7
On GEM operation, the switch requests the GEM into action operating the relay to pass power to the motor and to reverse the polarity.
When you go for a GEM module it has to be the exact unit and with the original program version because they are used in many different applications so the program version is per the original truck build.
Unless you find one from the same truck model and equippage, a dealer may have to program a new one.
What they will do is access a data base with the trucks VIN number and download the data or ID the data version your GEM needs to have loaded in.
Good luck.
Sorry it was such a chase but the learning/diagnostic curve comes at the same time and makes things more of a hassle.
Good luck on it.
Old Aug 23, 2011 | 11:27 PM
tofer76's Avatar
tofer76
im hopeing it wont come to that as almost 98percent of the posts ive read here and other sites were solved w a t case motor swap but im prpared for it
i know how to engage the 4wd manually if need be and ill just switch the vac lines in front to lock the wheels but im hoping that i dont have to go most of the winter w o 4wd as i wont have the money for a gem swap until tax time in march unless i can as you say find a identical truck in the boneyard
Darall
2004 - 2008 F150
Mar 12, 2018 01:44 PM
chessplayer41
Jul 10, 2017 04:25 PM
Pigman54
Jun 7, 2014 10:25 PM
panelguy
General Automotive Discussion
Dec 30, 2007 01:10 PM
