Big Block Overdrive
Old Dec 4, 2011 | 07:26 PM
Sleepy445FE's Avatar
Sleepy445FE
Originally Posted by graflexmaster
I hate to tell you Brain, but Ford bolted an overdrive behind the Fe for many years begining with the first Fe the 332 in 1958. The normal overdrive was the B-W T-85 with an R-11 OD. This was offered in the cars (long tail housing) from 1958 into the mid 60's. and in the F series trucks (W/short tail) from 1965 thru 1971.
The other overdrive Ford offered was the B-W T-86 w/OD that was commonly used behind the inline sixs and the 292 V8's.
Well... you learn something everyday. Thanks for the info! Reps....
Old Dec 6, 2011 | 01:55 PM
graflexmaster's Avatar
graflexmaster
Originally Posted by rustywheel68
true enough...but like BrainDamage said- you're not going to find one.
The Borg-Warner Overdrive Transmission Explained- FORDification.com
plus...due to the problems that could be caused if you didn't understand the freewheel, wasn't this design outlawed for the most part?
Actually Rusty the Borg-Warner Od's are not that hard to find (infact I have several out behind the shop). The light weight -86's were used by mfg's other than just Ford, such as Studebaker and AMC(Rambler/Nash/Hudson/etc). and Both Studebaker and AMC used the T-85 as well as Ford. In fact the well known AMC "Twin-Stick" used in the Rambler/AMC Marlin and Rebels was a B-W T85 OD.
As to the legal quesion, that is/was an urban myth as many other car mfg's continued to use OD trans. long after the big-3 US mfg's dropped them. Mfg's such as MG/Volvo/Triumph/etc continued to offer OD trannys well into the 80's.
Old Dec 12, 2011 | 06:27 PM
frty7ford's Avatar
frty7ford
Michael what do you have back there and are you looking to get rid of one
Martin Torres
Nov 26, 2018 10:05 AM
F-250 restorer
18
Jul 27, 2014 05:13 PM
dlmoore
Jun 13, 2006 02:07 PM
hotwheel
20
Apr 2, 2005 09:21 AM
elsmith
Mar 31, 2001 01:07 PM
