New trans
Old Aug 20, 2011 | 03:21 PM
  #31
Lazy K's Avatar
Lazy K
Ford Axle Code Chart .: Articles Here is a to the door sticker decoder. Check the axle code on your door sticker and compare to this chart (ignore where it says 1991) to find out what ratio you have.
And yes, the E4OD is computer controlled so you would need the PCM and transmission wiring harness from a donor truck or a stand alone controller.
Old Aug 20, 2011 | 03:24 PM
  #32
Lazy K's Avatar
Lazy K
Ford Axle Code Chart .: Articles Compare your door sticker axle code to this chart (ignore where it says 1991) to find out what ratio you have.
The E4OD is computer controlled (unlike the C6) so you would need the PCM and trans wiring harness from a donor truck or a stand alone controller.
Sorry double post.
Old Aug 20, 2011 | 03:29 PM
  #33
cj06's Avatar
cj06
Ford 2.9 MAF Conversion by Bob Marrs
custom air intake and MAF conversion for a 1988 Ford F150
Old Aug 20, 2011 | 04:27 PM
  #34
BlueOvalMarine's Avatar
BlueOvalMarine
I'll check that out. Thanks for the info!
martyanderson10
16
Mar 4, 2015 12:05 AM
arlan in arizona
May 5, 2013 12:05 PM
kmprr
May 12, 2009 11:38 AM
tankrsc
Apr 5, 2008 08:17 PM
3/4ER
Sep 8, 2005 11:23 AM
