91 150 jerking.
Old Aug 19, 2011 | 12:54 PM
joekacker's Avatar
joekacker
91 150 jerking.
Hey I have a 91 f150 that I just bought and have been working out the kinks, The original problem was alot of jerking under load especially hills, and at low rpms, So I decided to do a tune up i figured it was never done, Wow was I right , plug gap was 75!!! 6 wires broke off and were stuck to the plugs, so i did a full tune up . PCV valve, Air Filter, Plugs,( gapped them to proper specs, ) Wires, Cap, rotor, fuel filter..
Now the truck only jerks when holding a constant speed?? when I accel it goes away no problems, and decell, same thing no jerking, Just when im trying to hold a constant speed. Any Ideas?? I cant think of anything besides bad injectors or clogged any tips appreciated.
91 f-150 2wd 302efi
Old Aug 19, 2011 | 01:02 PM
Alec94F150XL's Avatar
Alec94F150XL
Definitely your TPS. I have the same problem on my truck. Rock solid answer though.
Here's a link to my thread explaining my symptoms, which are identical to yours.
https://www.ford-trucks.com/forums/1...help-asap.html
Old Aug 19, 2011 | 01:03 PM
Alec94F150XL
Haven't gotten around to fixing it, but will soon. I'll update when I do, or if you end up doing it first, then let me know if this solved your problem.
Hope that linked helped. Good Luck!
Old Aug 19, 2011 | 01:33 PM
joekacker's Avatar
joekacker
What is Tps. Im new to fuel injection. Some sort of sensor I would assume.
Old Aug 19, 2011 | 01:51 PM
White 97 xlt's Avatar
White 97 xlt
Have you pulled trouble codes yet? You can throw parts at until you accidentally hit the right thing, or run DTC codes and let the truck tell you what it needs..
BTW..... TPS is throttle position sensor
Old Aug 19, 2011 | 01:59 PM
joekacker's Avatar
joekacker
Yeah I wish I had a code reader That would be awesome. Your right though. I forgot about the code reader diognostic
Old Aug 19, 2011 | 02:33 PM
White 97 xlt
You don't need a code reader, although it makes it MUCH easier.. Just go here: Ford Fuel Injection » How To Run a Self-Test
Old Aug 23, 2011 | 07:42 PM
joekacker's Avatar
joekacker
I think dude was right. In the book it says bad tps will cause surging and jerking, hesitation on accel, sudden dieing of the engine, and unsteady idle, That just explained everything that happened. Thanks for that link to self Diog that will come in handy! Appreciate it fellas
Old Aug 23, 2011 | 07:49 PM
Alec94F150XL
Hope you fix the problem soon and you go about loving your truck!
Old Aug 24, 2011 | 05:07 PM
joekacker's Avatar
joekacker
Oh I still love the truck. 121,000 miles. Perfect interior. All I've had to do Is u joints two front tires. Full tune up. 800 bucks can't go wrong
Old Aug 24, 2011 | 05:11 PM
joekacker's Avatar
joekacker
I wish the manual showed mire in depth on the tps removal and install.
Old Aug 24, 2011 | 07:20 PM
Alec94F150XL
Ha nice, I got around to fixing the TPS on my truck, well replaced it with a Motorcraft one. Runs smooth! So far..... Hope this is the permanent fix!
Hope you get to fix it!
Old Aug 24, 2011 | 07:40 PM
joekacker's Avatar
joekacker
How long did it take. Im taking my truck on a 400 mile road trip. The maiden voyage lol
Old Aug 24, 2011 | 11:23 PM
Alec94F150XL
Took me about 10 minutes. But I have the 4.9 300 I6, my throttle body is easy as hell to get to. Your 5.0, well that's a different story!
Sorry.
Old Aug 30, 2011 | 09:02 PM
joekacker's Avatar
joekacker
I went and looked at it the other day, and then I looked at the sun, Then I looked back at the truck, Then I looked up at the sun, Then I looked at My cold beer. And Said Not NOW.. Is she running better though, Did you notice any difference in the down shift at all?
