gas gauge
Old Aug 23, 2011 | 11:02 AM
redneckcustoms13's Avatar
redneckcustoms13
Originally Posted by jsutton
Disconnect the wire running from the sending unit to the front of the truck (should have a quick connect on it, just unplug it) and ground the wire that runs to the front. The gauge should peg to full, if it does then you know the gauge and wiring are working.
thanks man, i dig your truck, looks like your blitz black actually turned out flat... how much did you reduce it?
Old Aug 23, 2011 | 11:26 AM
jsutton's Avatar
jsutton
No problem, I hope you get the issue worked out. I have had to replace the float in my tank 2 times.
Thanks!
I reduced it 8:1, the instructions that came on it said 10:1, but after a lot of reading and seeing a lot of people doing it 8:1 I went with that ratio. It has faded some over the last 5 years from being out in the Louisiana sun everyday and my lack of dedication to keeping the paint looking good. I'm thinking very seriously about going back with the dark jade metallic since I have a place to keep it out of the sun now at the new house.
Old Aug 23, 2011 | 12:56 PM
rmodel65's Avatar
rmodel65
i like the imperial jade on the toyota trucks
Old Aug 23, 2011 | 02:09 PM
redneckcustoms13
guess 8:1 will be my next try. i am PISSED at how mine turned out
Old Aug 23, 2011 | 02:20 PM
jsutton's Avatar
jsutton
A lot of stuff you read says it's okay to reduce it with Mineral Spirits, which I did when I painted the hood, but then I used the JD reducer for the rest of the truck and liked it much better. It just dried better to me, but this was my first time painting anything and I wasn't going for show car quality, I just wanted it all one color cheaply. And I wanted it to look kinda mean, even if it wasn't.
Old Aug 23, 2011 | 02:33 PM
redneckcustoms13
i used jd. but i am extremely disappointed by the way it turned out. ill normally use an industrial fleet paint for a peterbilt frame its pour and go, lays thick, spreads well and is a great paint. but just not quite as flat as i wanted.
Old Aug 23, 2011 | 02:50 PM
rmodel65's Avatar
rmodel65
ive got some JD Blitz Black i was planning on putting it on my 85f150 but i sold that...so i might put it on my 95 Mustang GTS...or use it to to paint the frame and stuff on my Dent
jerryst
Sep 30, 2012 11:26 AM
Luckie117
Bronco II
Oct 3, 2005 09:56 AM
lpmorgan
Sep 25, 2005 05:04 PM
blakesdadfishing
Jan 21, 2004 02:06 PM
