1971 ford truck dash lights
on
Thipdar great tip on the JB Weld for that bracket. It is definitely a great trick and just used the same on mine. Otherwise you need 4 hands and a set of mirrors I swear! Especially on mine as the AC unit goes under the column and has a vent right under that switch. A MAJOR PITA even with that bracket attached for mine!
I remembered that a previous switch I had to replace (probably the original on my other '70) had the bracket spot-welded in place. I can only assume that the bracket became "optional" because the remaining part of the switch is also used elsewhere in land.
on
First of all, you shouldn't need the engine running - the instruments lights are supposed to work even without the key in the ignition - even with the truck completely off, the headlights, high beam indicator, instrument lights and courtesy lights all should work.
If you disconnect the connector from the switch, you'll want to test two pins on the switch with an ohmmeter, to see if the resistance between them changes when you rotate the switch ****.
The symbol for the rheostat and the two pins that connect to it are circled in red.
This diagram should represent the placement of the various pins on the switch, and you'll need to make sure you get the two correct pins.
The connector is shown here as a mirror image of the place where it plugs into the switch.
The part of the diagram that indicates where Wire #25 goes into the connector is the wrong side to test - instead, check the pins that are on the actual switch body.
on
Disconnect the battery.
Take the Instrument Cluster out if you need extra room to access the switch.
Remove the light switch and "bench test" it.
There's a spring-loaded button on top of the switch housing that will release the switch **** & shaft from the switch.
Once you remove the switch from the dash, re-insert the switch **** & shaft into the switch, so you can operate the rheostat during testing.
If it turns out that you need to replace the switch, you may find the replacement part includes a loose bracket - I glued mine in place with some JB Weld, in order for the spacer to stay put during re-assembly.
Thipdar --- Thanks for the information on removing the instrument cluster to get some room to work on the headlight switch. I tested all the fuses in the fuse block and that was about all I could down in the well.
Also with the instrument cluster out I can 12 volt jumper the instrument light bulb feed to see if they are all working.
Thanks, I would have missed that for sure. I know I am doing a lot of testing and it still may be the light switch that needs replacing like most have said, but as a new owner all the testing is helping me understand this year electrical system. As I am retired I have nothing but time to work on this new "OLD" truck.
On my 70 f250, I have had a dash light rheostat problem as well. At one point I bent the little tab for more pressure on the spring for dimming the dash. That worked for a while, sometimes. I pulled the 2A fuse out and it was bad but I couldnt find 2A at orielleys and forgot about it. Then my headlights wouldnt work but high beams did. Last week I finally replaced the head light switch, which I had for over a year. Still no headlights. I just got finished pulling bulbs out and cleaning terminals. One of the terminals came apart on passenger headlight. I disconnected the grounds and cleaned those. Put one together and checked, still no headlights but still had high beams. Then I dropped driver side headlight while brushing the dust off the back. Got two headlight from oreilleys then found 2A fuse at NAPA. New headlights in and they still didnt work. Put in the damn 2A (short)fuse for my instrument panel and finally headlights. I didnt know panel and headlights were the same fuse. I know that was long winded but might accidentally help someone.
greenmachine86
15
08-28-2016 07:10 AM
Zachthemoo2
09-18-2014 11:34 PM
Lennyloafer
05-20-2009 11:33 AM
