My overhead console is like yours!! And I am hoping that someone out there has the overhead gauges with our console. That and I want to see what it looks like.
My wife has the overhead console and a quad pod in her excursion. Works fine.
If you use good quality velcro you will not have issues. Mine has been installed for years without issue.
Joe, OT for a second, but what temp your rear diff run at? Im thinking about adding that gauge myself.
I keep checking mine with the infared gun cause I'm worried about the drone its making.
Thanks, back to your regularly scheduled program....
Empty it will run 170* or so when its hot out, pulling I have seen 220* or so. I am waiting right now for a ride to my truck. Once I get there I will peak recall the temp, I just pulled my trailer from Santa Fe to Colorado Springs a few weeks ago and I know it got hot!
10-4, I appriciate the info.
Thats on par with with the temps I'm seeing empty.
I'll compare your peak with what I see pulling my camper back to FL in two weeks.
I have been kicking around the idea of the windshield mount gauges. But seeing that some have had bad luck getting to stay just wondering if that still holds true.
Is it worth buying?? Or has anyone had any luck with a mod or trick that holds it in place?
