1996 Powerstroke e4od
Old Aug 17, 2011 | 09:49 PM
barbqman's Avatar
barbqman
Works fine part of the time other times it will only take off forward at about 1500 rpm but reverse always engages good warm or cold . When it hit 15 to 1800 rpm it will take off and no slipping at any gear change . I drove it the other day to get codes up but it never missed a lick. Does any one know what could be wrong ? It has new filter and fluid and double check filter it is in place correctly .
Old Aug 17, 2011 | 09:58 PM
bad12jr's Avatar
bad12jr
More info on the truck please ( Miles, year etc) and welcome to the forum
Old Aug 18, 2011 | 08:43 AM
barbqman's Avatar
barbqman
It is a 1996 F350 Centurion 4 door stretch 320,000 miles this is third trans with about 20,000 miles I got stuck in mud but did not give it a hard time I went and got tractor and pulled it out and this problem started . I cleaned wire hook UPS on both sides of trans but did not help . Pulled pan but there was not any metal or clutch fibers in it . Put in new filter and fluid but it didn't help . I have rebuild several old autos of my own one in my sons 750 HP show show truck but never worked electronic trans before .
Old Aug 18, 2011 | 09:02 AM
DIYMechanic's Avatar
DIYMechanic
Mark Kovalsky is the guy you need to talk to. He is a former Ford auto transmission engineer who knows his stuff when it comes to matters like these. I will see if I can get him to head over here and offer an opinion.
Old Aug 18, 2011 | 05:28 PM
barbqman's Avatar
barbqman
Thanx
I will wate to here from him . I forgot to put this in post don't know if it makes any difference but it is 4x4 .
Old Aug 18, 2011 | 08:04 PM
DIYMechanic
I sent him a PM. I know he is a busy guy, so hopefully he will be around. My WAG is that there is a band that is slipping to engage first gear.
Another thing that comes to mind is that the transmission linkage may be out of adjustment. Does it engage first if you pull the shifter down into 1? Does it shift into all four gears when you are driving it? It doesn't seem like you're starting off in second gear does it?
Old Aug 19, 2011 | 09:36 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There are no bands, so that's not it.
Will it engage normally if you put the shifter in 1 or 2?
Old Aug 19, 2011 | 10:21 AM
DIYMechanic
See, that's why he is the expert and I AM NOT!
Old Aug 19, 2011 | 02:24 PM
barbqman's Avatar
barbqman
Pull it to 1st it doesn't engage any better but in drive when it gets to 1500 to 1800 it takes off and shifts normal does not slip in any gear . One 74 yr old mechanic friend thinks it is torque convertor or selenoid bad . Haven't got it bring up any codes yet . It was working fine one minute and then it isn't . Like I say I sunk it to the frame in soft ground in 4 wheel drive I pulled forward and backed up a couple times I wasn't hard on it I knew that it wasn't coming out so went got the 4 wheel drive Ford tractor and pulled it out and then it started acting up . Like I say I didn't crowd it I am 62 years old I got a farm here I had been back there several times before but that day I got about 25 yrds from stock pond and it went down .
Old Aug 19, 2011 | 02:52 PM
DIYMechanic
Have you by chance checked the electrical connector on the side of the transmission? Is there any chance that the truck was up in the mud far enough to jar that connector? It may be worth pulling the connector off, and inspecting it, cleaning it up good, and reinstalling it.
Old Aug 19, 2011 | 04:10 PM
barbqman's Avatar
barbqman
Yes that was the first thing I done but I think I will clean them again just in case I missed something. I used brake parts cleaner and let them dry and then sealed them with silicone electrical grease . yea the front went down to the cross member rear almost to punken . This thing is super heavy it didn't spin down it just sunk but I was spinning while tractor was pulling me out with all four wheels in reverse witch was back the direction I came from . Then I pulled up farm gravel road about 50' took it out of 4 wheel drive and with in a 100' or so it was messing up .
Old Aug 19, 2011 | 05:32 PM
Brown Falcon's Avatar
Brown Falcon
Just a thought, have you checked the VSS on top of the rear diff? That connection could be loose or have water in it...
Old Aug 20, 2011 | 08:16 AM
barbqman's Avatar
barbqman
vss
Yea I replace it about 3 months back when spedo quit and trans started shifting hard but I checked it and it is ok .
Old Aug 22, 2011 | 12:00 PM
barbqman's Avatar
barbqman
I am in process of cleaning and checking all electrical connections to see what it does .
Old Sep 2, 2011 | 05:32 PM
barbqman's Avatar
barbqman
change over
I give up be changed to 5 or 6 speed soon as I figure out what year models will work in place of it .
