2011 F150 engine choice
Old 08-17-2011, 07:45 PM
boss1982's Avatar
boss1982
boss1982 is offline
I am seeking data/recommendations for engine type in the 2011 F150. I currently pull a 6000 lb trailer with a 2002 F150 with the 4.2L V6 and it seems to struggle alot going up hills, plus it has 150,000 miles on it. I am wondering which engine would best meet my needs between the V6 3.5L Ecoboost, the V6 3.7L FFV and the V8 5.0L FFV.
Old 08-17-2011, 08:58 PM
dilas's Avatar
dilas
dilas is offline
From the posts here, 3.5L Ecoboost get lot positive raves for power and fuel efficiency combination. I test drove one earlier this summer, and I was VERY impressed with the ECO engine. It's probably the best choice. I believe you can't go wrong with 5.0L as well. Since you're pulling a 6K trailer, I would go either with 3.5L or 5.0L. I tow a 6K travel trailer on my 2002 before trading for a 2007 recently. Wouldn't go less than 5.4L on both generations. Yet, the ECO is brand new design, and I would be somewhat hesitant on investing good $$ on the first year design without bugs being ironed out. 5.0L would be safe bet in my opinion being a stout traditional V8 engine. That's just my conservative opinion.
Old 08-17-2011, 09:00 PM
spdmpo's Avatar
spdmpo
spdmpo is offline
Any of those engines will outdo your current truck, so you can't go wrong. Bottom line is it's your choice on how much you want to spend, and what you are looking for in the truck.
Old 08-18-2011, 04:57 AM
FORD FRED's Avatar
FORD FRED
FORD FRED is offline
To get the best answer to your question you need to provide as much info about your situation as possible. When we know how often you tow and how far and the terrain and the type of driving you need the truck to be capable of when not towing we can then suggest the engine and gear ratios that would be best for you. Do you need 4x4 ? Or do you need 2x4 and maybe limited slip? Are you going to lift and put on larger tires? Is your commute at highway speeds? etc... etc... etc...
Old 08-18-2011, 05:26 AM
shortride's Avatar
shortride
shortride is offline
The 6.2 V8 gets fairly good fuel mileage for its size but I think I would go with a 3.5 Ecoboost. The EB has plenty of Hp and torque and it weighs less than the 6.2 V8. The EB engine weighs 449 lbs. The 6.2 engine weighs out at a hefty 590 lbs. according to this article.
MaxPower01
2009 - 2014 F150
01-23-2018 06:30 PM
Scott Marcum
2015 - 2020 F150
06-30-2017 10:03 AM
KIEV
2015 - 2020 F150
02-19-2015 03:55 PM
tolliewolly
2004 - 2008 F150
03-12-2010 10:19 AM
keith j.
1997 - 2003 F150
10-29-2004 05:45 PM
Quick Reply: 2011 F150 engine choice
