I need to get new rotors for my 69 F350, but every supplier that has been called says that the rotors are discontinued and cannot be ordered.
I thought I read somewhere that the F250 and the F350 rotors were the same, but when suppliers are asked, they say they have different part numbers. The strange part is that they said they can get me rotors if the truck was a dually, but not for a standard 4 wheel truck. Does that make sense? Did they run different rotors up front for the dually trucks?
Anyway, does anyone have any input to help me out here? What rotors could I order for my F350 since the "numbers" in everyone's systems have those rotors discontinued? And if anyone knows where I might be able to order some, can you please point me in that direction?
In the meantime, I guess we will have the F250 rotors ordered and compare them to see if they look the same. But any response is appreciated and the quicker the better!! I want to have the brakes done by this weekend!
My gut feeling is that the F250/F350 rotors will be the same. Raybestos part number 6024R. The calipers show as the same for both trucks. You could check the bearing part numbers between the two trucks. If they were the same there's a real good chance they're the same.
