Spedometer off?
Old Aug 17, 2011 | 11:40 AM
Crewcab Turbo's Avatar
Crewcab Turbo
Spedometer off?
My spedo reads aprox 5 mph higher than I am going I have 285 tires bigger than stock size. Normally wouldn't it read slower not faster? Has been this way since I got it. Any way to fix this? Thanks!
Old Aug 17, 2011 | 11:52 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
So 5 MPH all the time or 5 MPH off at a certain speed? Different causes for each.
The speedometer can be corrected in the ABS (antilock brake) module or by using a piggyback module like a superlift tru-speed.
Old Aug 17, 2011 | 12:11 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Do you have or know anybody in your area with AE? It can be used to correct it.
Old Aug 17, 2011 | 02:18 PM
clem1226's Avatar
clem1226
this is just a WAG but if your truck had the lift on it when you bought it I bet it had bigger tires at one time and the spedo was corrected for those bigger tires.
This could be corrected with AE or at the dealer if it is the case.
Old Aug 17, 2011 | 02:24 PM
Crewcab Turbo
My truck did have bigger tires before I got it, 35" or so. I just didn't think it would be 5 mph for just a size or two?
Old Aug 17, 2011 | 03:29 PM
clem1226's Avatar
clem1226
how did you verify vehicle speed? GPS, mile marker....that game the local police department puts up on the trailer?
5 MPH off would be about right if your truck is calibrated for 35's and you have 33's
Old Aug 17, 2011 | 03:43 PM
Crewcab Turbo
I used a gps to test speed
Old Aug 17, 2011 | 03:46 PM
PaysonPSD's Avatar
PaysonPSD
Check to see if there has been an aftermarket speedo recalibrator added, like a Yellow Box or a Tru-Speed.
Old Aug 17, 2011 | 03:48 PM
Crewcab Turbo
Where would that be?
Old Aug 17, 2011 | 04:12 PM
PaysonPSD's Avatar
PaysonPSD
Sorry, I have not installed either. You will have to open the links I posted and check the instructions.
Typically both are mounted inside the cab. Under the dash I would think.
Tylus
Dec 7, 2011 05:21 PM
V8Ranger302
Jul 9, 2010 06:48 AM
SilverBullet131313
Mar 5, 2010 07:13 PM
John311t
Jan 24, 2007 10:25 PM
wyoguy
Apr 16, 2006 05:07 PM
