Bolt Pattern
Old Aug 17, 2011 | 12:23 AM
SuperDuty93's Avatar
SuperDuty93
Bolt Pattern
Hey yall. Im about to order some mickey thompson classic 2 wheels and want to make sure the bolt pattern is correct. I have a 1974 F250 4X4 with a 78 front end.
Are there any other parts i need to order with the new rims like center cabs (the ones that stick out)?
Old Aug 17, 2011 | 01:28 AM
mjshagnasty's Avatar
mjshagnasty
It should be 8 lug on 6.5"
Old Aug 17, 2011 | 06:18 AM
Mauch1's Avatar
Mauch1
You dont have to get center caps but you can if you want. Depends on what you like.
Old Aug 17, 2011 | 07:23 AM
JNeely's Avatar
JNeely
The Classic IIs will include chrome plated center caps with purchase of the wheel.
Be cautious of them, though, as they are cheap chrome plated steel pieces and mine have already started to rust after having had them on there for a couple of months. It's the middle of summer, and this thing has never seen salt.
The do sell stainless ones as an upgrade if you're so inclined. I just gave my axle ends a fresh coat of black paint and went without.
Old Aug 17, 2011 | 07:41 AM
KrautBurner's Avatar
KrautBurner
All 8 lug wheels are the same bolt pattern (prior to 1999)
+1
Now post pics (before/after)
Old Aug 17, 2011 | 08:27 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Have you figured out your front wheel offset to avoid hitting front end power steering servo? I think is might be an issue, HB owners post up!
And yes on 8 on 6 1/2 NOT 8 on 177MM
Old Aug 17, 2011 | 08:37 AM
JNeely's Avatar
JNeely
I'm running the 17" classic IIs, which are only available in 17x9 with the 5" backspacing.
My highboy has a 79 steering box, but I have a dual shock setup that I have to clear. I was hesitant at first, but I have 1" wheel spacers all around. Haven't had any problems so far. This reduces backspacing to 4".
My father's hiboy has the stock steering setup. He runs 16.5x9" rims with 5" backspace. The tires are 36x16.5x16.5. He has a slight rub on the control valve on a hard right turn, but nothing severe. Maybe he's misread the backspacing information, but I don't think the steering servo should be a problem for most people...
Old Aug 17, 2011 | 08:48 AM
77&79F250's Avatar
77&79F250
Thats what I'm talking about there JNeely.....thanks.
Old Aug 17, 2011 | 09:04 AM
JNeely's Avatar
JNeely
Sorry, I don't have any pics of the rear readily available.
Here is one of the fronts with the spacers:
Old Aug 17, 2011 | 10:27 AM
SuperDuty93
Ok so here are the ones im looking 4 i think. I will be running 35X12.5 tires. I like them to stick out of the well's a little. Will these work with a 74 Highboy?
Mickey Thompson Part 360481 - Classic II Alloy Wheel by Mickey Thompson
Old Aug 17, 2011 | 10:43 AM
JNeely's Avatar
JNeely
I would imagine they will stick out a little bit without looking funny.
You should check that they clear your front brake calipers, though. Maybe someone else can verify clearance. The 16" aluminum wheel that I was able to test fit on my dual piston caliper setup did interfere, but it was an older eagle alloy or something like that.
Old Aug 17, 2011 | 10:55 AM
650's Avatar
650
As for the alluminum 16 inch wheels fitting. The only problem I forsee is if you have front calipers which I think 74 did not have. Anyway if you do you will either need to grind down the calipers for the aluminum wheels to fit or just get 17`s.
Old Aug 17, 2011 | 10:57 AM
650's Avatar
650
Also you should check your backspacing. If you look in a Summit catalog they have a little instructional paragraph on how to in the wheels section.
Old Aug 17, 2011 | 11:06 AM
JNeely's Avatar
JNeely
I thought he stated he had a high pinion...? This would indicate disc brakes.
As far as protrusion from the wheel well, you should have approximately .75" less than my truck if you run the 4.4375 bs 10" wheel with 12.5s
Old Aug 17, 2011 | 03:34 PM
SuperDuty93
I have a 78 front end so i have discs. I just wana make sure they wont rub and they shouldnt but there is always something going wrong
ScythEmpress
Jan 23, 2011 01:15 PM
6578trk
Jul 27, 2006 09:57 PM
95_4x4_jay
Feb 4, 2005 10:52 AM
michaelbrainardatwor
Jan 27, 2005 06:47 PM
intelsoldier
Feb 27, 2003 06:13 PM
