351M Timing Chain
Old Aug 16, 2011 | 09:46 PM
amodel55's Avatar
amodel55
351M Timing Chain
When I install a melling RV cam in my 351M should I up grade the timing chain and gear or will stock be ok? Thanks/Robert
Old Aug 16, 2011 | 10:40 PM
Bgasrickshaw's Avatar
Bgasrickshaw
I always go with a true double roller chain and steel gears. I find they last longer with less stretch than the stock aluminum/plastic cam gear set, although they might be a bit noisier, if that concerns you.
Old Aug 17, 2011 | 08:59 AM
lance65's Avatar
lance65
put in a Cloyes, Comp Cams,Edelbrock TRUE ROLLER. The factory set is retarded about 4*. The ones listed are straight up which will improve power and enhance any cam that you install.
Old Aug 17, 2011 | 11:29 AM
ctubutis's Avatar
ctubutis
What he said.
Old Aug 18, 2011 | 02:18 PM
amodel55's Avatar
amodel55
351M Timing Chain
Thanks Guys.
Old Aug 19, 2011 | 07:29 PM
amodel55's Avatar
amodel55
Roller sounds better and should reduce friction (How much noise you talking about?)
Also I have never had a set of roller rockers, should I consider those or is that a big waste of money! Thanks/Robert
Old Aug 19, 2011 | 07:35 PM
ctubutis's Avatar
ctubutis
I wouldn't be considering roller rockers if I were you unless I had leftover money burning a hole in my pocket:
https://www.ford-trucks.com/forums/3...r-rockers.html
ThatFordGuy
May 16, 2011 11:25 PM
jacfordf-250
Dec 29, 2010 06:43 AM
justforkicks
Jun 28, 2009 06:57 PM
jdon88
Dec 16, 2003 12:14 AM
Mil1ion
May 30, 2002 02:13 PM
