fuel problem
Old Aug 16, 2011 | 08:47 PM
Dvandy21's Avatar
Dvandy21
fuel problem
Opps, I was reading through some threads on the 1987-96 thread and accidentally posted my question in the wrong thread, but... for the past week or so when I started my truck it sputtered and coughed once or twice then it ran just fine. Then tonight I started it and it ran just fine, but I went out to move it later and it randomly started shaking and sputtering quietly and then shut off. I'm thinking it has to be some sort of fuel issue, but I'm not sure what? Any suggestions?
Old Aug 16, 2011 | 09:18 PM
oldbird1965's Avatar
oldbird1965
Try a new filter and clean the FPR screen. Check your fuel pressure, it might be low.
Old Aug 18, 2011 | 06:19 AM
Dvandy21's Avatar
Dvandy21
Still havent diagnosed the issue yet, but a buddy of mine came over last night and checked it out. The truck will turn on and idle still, but it sounds like it has a miss and it idles very low. if you let it idle for a little while or give it gas, you can get the rpms to go up and you can even get the truck to drive, but not very well. I don't know if that helps at all, but any info would be appreciated.
Old Aug 18, 2011 | 06:48 AM
Copedawg's Avatar
Copedawg
Have you tried unplugging the ICP to see if it starightens out?
Old Aug 18, 2011 | 06:49 AM
DIYMechanic's Avatar
DIYMechanic
Try unplugging the ICP sensor and starting it up. Could be a stuck IPR or a bad ICP causing very low HPO pressure to the injectors.
Dangit Ian! you beat me to it.
Last edited by DIYMechanic; Aug 18, 2011 at 06:49 AM. Reason: Ian types faster than I do!
Old Aug 18, 2011 | 07:25 AM
oldbird1965
How old are your injectors?
Old Aug 18, 2011 | 10:13 AM
fordpride's Avatar
fordpride
Have you checked the fuel pressure?
Old Aug 18, 2011 | 02:53 PM
Dvandy21's Avatar
Dvandy21
I'll check the ICP. Haven't checked the fuel pressure yet, but I'll do that too. As far as the injectors, I believe their the stock ones, so 118,000 miles. Thanks for the responses, guys, I'll try some stuff and get back to you.
Old Aug 18, 2011 | 09:05 PM
oldbird1965
118K isn't bad, maybe empty the fuel filter canister and fill it with PS.
Old Aug 19, 2011 | 12:50 AM
Brown Falcon's Avatar
Brown Falcon
Sounds like valve cover harness issues. Check the plugs on the valve covers for burnt pins.
Old Aug 20, 2011 | 05:52 PM
Dvandy21's Avatar
Dvandy21
I replaced the fuel filter today and that helped a lot. Truck sounds much better than it did before, but its still not perfect. It really struggles at idle and even when you floor it in park, it can only reach about 2100 RPMs. I tried unplugging the ICP sensor, but that didnt make a difference. I havent checked the fuel pressure yet because I'm not sure of the best way of doing it. Should I run a piece of fuel hose to the fuel purge and hook a gauge up to that?
Old Aug 20, 2011 | 08:32 PM
DIYMechanic
To check the fuel pressure just use a cheap stick style tire gauge. It will have to be a 75 or 100 lb range gauge, but you can just check it at idle on the Schraeder valve (it has a cap on it) on the side of the Fuel Pressure Regulator on the driver side of the fuel bowl. You should see 65-70 PSI at idle. Anything less and you either need to replace the pump, or shim the FPR with the "BB mod".
Old Aug 20, 2011 | 10:30 PM
Brown Falcon
Try unplugging the MAP sensor and see if it helps...
Old Aug 23, 2011 | 06:04 PM
Dvandy21's Avatar
Dvandy21
The fuel pressure at idle was between 50-60psi, usually close to 55psi. I unplugged the MAP sensor and when I stepped on the gas was easily able to get it up to 3000+ RPMs within a second or so. Before I had to flat foot it for a couple minutes just to see 2000 RPMs. It still wont idle right, but I'm assuming that's just because the air/fuel mixture is off with the sensor unplugged? Do you guys think its the MAP sensor then? Just wanted to check with the experts before I go buy one.
Old Aug 23, 2011 | 06:32 PM
Copedawg's Avatar
Copedawg
make sure your tube is clear going to the head/valve cover
