Missing EBCM
Old Aug 15, 2011 | 08:02 AM
ahmincha's Avatar
ahmincha
Missing EBCM
As stated in title we bought a truck from auction and the ebcm is not there. My ? is i do not have a speedometer and i want to make sure that the speedo goes through the ebcm. Also will it hurt the trans being there is no speedo signal. Thanks in advance
Old Aug 15, 2011 | 09:08 AM
dchamberlain's Avatar
dchamberlain
What is an EBCM and where is it supposed to be? What year, model, engine, etc truck are you talking about?
Old Aug 15, 2011 | 09:26 PM
ahmincha's Avatar
ahmincha
Sorry for lack of info 2000 f550 7.3 diesel electronic brake control module It gets bolted to the anti lock brake hydraulic pump. Also wondering am i right that speedo wont work without it
Old Aug 15, 2011 | 09:33 PM
dchamberlain
OK. I understand now. I have zero knowledge of big truck stuff, so I'm afraid I can't help. Hopefully someone else who knows about that kind of stuff can.
There is a Large Truck forum right below this one. I don't know if an F550 would fit into that category or not.
Old Aug 15, 2011 | 10:06 PM
twags6's Avatar
twags6
F550's fit into the SD forum. Come on down to the 99-03 7.3 forum.
The speedo runs off of the VSS thats mounted on top of the rear differential. When they go bad, you'll loose the speedo and usually get an ABS light because it can't sense the rear axle speed. As far as affecting the trans, it will mess with the shifting since the truck doesn't know how fast its going.
Old Aug 15, 2011 | 10:11 PM
powerstroke72's Avatar
powerstroke72
Thread moved to the 1999 - 2003 7.3L Powerstroke Diesel forum.
Old Aug 15, 2011 | 10:14 PM
twags6's Avatar
twags6
Thanks John!
Old Aug 15, 2011 | 10:38 PM
powerstroke72
You bet! <fillllllllllllll>
Old Aug 17, 2011 | 03:44 AM
twags6's Avatar
twags6
Bumpity bump!
Old Aug 17, 2011 | 07:34 AM
ahmincha's Avatar
ahmincha
Thanks for moving the thread. Also thanks for the replies I do understand the vss part of the system. Where i am lost is does the signal go through the brake control module. In other words will not having the brake module on the anti lock brake pump will this disable my speedo
Old Aug 22, 2011 | 07:06 AM
ahmincha's Avatar
ahmincha
Anybody have any comments
Old Aug 22, 2011 | 09:05 AM
nlemerise's Avatar
nlemerise
As far as I know the VSS signal does not go to brake control module at all, though I am not certain of that. The VSS is attached to the differential (near the top). It would be worth the shot to replace the VSS sensor (available at NAPA) for under $20. If the VSS fails OR is unplugged you will not have a speedometer, that I know.
bradphx
Sep 25, 2016 02:37 PM
Aussie BrianB
Australia Chapter
41
Jul 27, 2013 09:53 PM
69ford99
1978 - 1996 Big Bronco
Dec 14, 2006 01:59 PM
