If that's your truck in second video it looks like it's time for a comp test. Normaly when checking for blow by through the filler neck you would place the cap over the hole to give an idea if it's pressure or vapor. If the cap bounces off it's a sign of broken or worn rings, or hole in cylinder. If the cap just kinda floats there your probably ok. Yours does look excessive!
Subscribing. I believe you have a bad hole also. The poffs of smoke seem to be timed like timing of cyclinders not blow by that is normal for these engines a steady flow.
Chet
The puffs of smoke seem to be timed like timing of cyclinders not blow by that is normal for these engines a steady flow.
Correct bad cylinder. Replacing with a ford reman. engine for $7000 including install for a complete drop in motor. It was cheaper that a $650 a month truckl payment.
here is what i am getting.
7.3L Ford Powerstroke Running Complete Engine
1999.5-2002 F250-F550 and Excursion with EBP Valve
Ford Part# XC3Z-6007-CARM
Engine serial # 896813-2030402
Ford remanufactured diesel engines are the only engines authorized by Ford Motor Company. Ford Motor Company engineering has rigorously tested and approved each remanufacturing process to insure compliance to Original Equipment standards. Long term durability resting has proven that Ford remanufactured engines will proved the service and durability that you demand.
The Running Complete Engine is offered with a 2 Year - unlimited mileage warranty, that is backed by Ford Motor Company.
Ford Powerstroke Build Level – 7.3L DIT
Ø 6009 – Short Block
· Cam Bearings
· Camshaft
· Connecting Rods
· Crankshaft Dowel Pin Kit
· Crankshaft
· Cylinder Block
· Lifters
· Main/Rod Bearings
· Piston Cooling Tubes
· Pistons/Rings
· Rear Seal
· Timing Components
Ø 6012 Long Block Stripped
· 6009 Short Block Plus
· Cylinder Head Assembly (updated 10 bolt Intake Style)
· Front Cover
· Front Seal
· Oil Cooler Assembly
· Oil Pump Assembly
· Push Rods
· Rear Cover
· Rocker Arms
· Valves
Ø 6012 Long Block Enhanced
· 6012 Long Block Stripped Plus
· Intake Manifold
· Oil Filter
· Oil Pan
· Valve Cover Gaskets
· Valve Covers
Ø 6006 Long Block Complete
· 6012 Long Block Plus
· Glow Plugs
· High Pressure Oil Pump and Regulator
· Injectors (Electronic)
· Oil Pan and Pick-up Tube
· Sensor – CMP Camshaft Positioning
· Sensor – EBP Exhaust Back Pressure
· Sensor – EOT Engine Oil Temperature
· Sensor – ICP Injection Control Pressure
· Vibration Damper
Ø 6007 Running Complete
· 6006 Long Block Complete Plus
· Adapter, Exhaust Inlet
· Engine Block Heater
· CDR Valve
· Exhaust Manifolds – Left and Right
· Fuel Filter Assembly
· Sensor – Water Temperature
· Tube, Exhaust Left and Right
· Turbocharger Assembly with Pedestal
· Water Outlet and Thermostat
· Water Pump Assembly
Running Complete Engine requires a complete core to be returned - Additional Core Charge of $3200.00 will be charged seperate from auction.
See Core Return Details below:
Ford and Motorcraft no hassle
Core Return Policy on Engines and Transmissions
Ford & Motorcraft's new "No Risk" core return policy means accurate quotes for engine and transmission replacements are "NO PROBLEM." "NO QUESTIONS" asked. Just follow these guidelines and the return will run smoothly.
