cdr
Old Aug 14, 2011 | 12:34 PM
gumper 123's Avatar
gumper 123
cdr
Do you guys no is the cdr a dealer item only? just pulled mine can blow threw it both ways that would explain the oil usage
Old Aug 14, 2011 | 01:56 PM
tecgod13's Avatar
tecgod13
PS use the search.. its been covered multiple times and part numbers are listed for both Ford and International dealers.
Old Aug 14, 2011 | 02:32 PM
Scratcher's Avatar
Scratcher
Ford calls this item a "Adapter assembly for Crankcase Ventilation" Part number E3TZ-6A665-A
IH part no is #1805319C1 and is cheaper
The seal does not come with the CDR. The ford Part Number for the CDR Seal is E3TZ-6A892-A. ...
The part # for the rubber tube on the CDR... Retainer # E8TZ 6A892A
Old Aug 14, 2011 | 03:10 PM
94 smokin stroker's Avatar
94 smokin stroker
Yep only dealer or IH will deal with you on a cdr tried to get my new one from local napa and no luck so the stealership got my cash
Old Aug 15, 2011 | 02:24 PM
gumper 123's Avatar
gumper 123
ok so i bought new cdr from stealership $63 i thought i read on here if you could blow through both ways it was bad i can blow through both of them.
Old Aug 15, 2011 | 02:57 PM
LSO1123's Avatar
LSO1123
I don't know but I have a stupid question. Where is the CDR on a 7.3 N/A? I know where it is on my IDI turbo but I don't see it on the NA.
Old Aug 15, 2011 | 03:01 PM
84-6.9L's Avatar
84-6.9L
A CDR is tested by checking the diaphram, there is a small pin hole on the face of it, suck on it and see if it moves internally. And on an NA motor it is on the back of the intake, mounted in the valley pan.
Dean06919
Jul 27, 2016 06:11 PM
dsphoto
Jun 29, 2016 01:58 AM
fasthauler
Jan 12, 2012 03:41 PM
guthrie&co
Jan 27, 2009 03:29 PM
spankin460
1997 - 2003 F150
Mar 13, 2005 08:20 AM
