Not the normal cross-fueling problem
Old Aug 13, 2011 | 11:06 PM
Fordenthusiasts's Avatar
Fordenthusiasts
I researched this issue quite a bit and haven't found one like mine. My problem is I can fill both tanks full, then drive on the front tank only, and when I switch to the rear tank (if it matters I switch from front to rear tank when front reaches 1/4 tank left) it shows less than full. Most of the time it shows just to the left of the full mark but not to the 3/4 mark. I have verified that after filling up the rear tank that the level reads a little over full, so its not a bad sending unit. Also I only get about 60-70 miles on the tank before it gets to the halfway mark, whereas my front tank can get 120-130 miles at half. And the rear tank normally gets about 2 mpg worse than the front.
I thought I had the cross-fueling issue but what I've found seems to say that the check valves go bad and fill the other tank, but I never use the rear tank before the front one, so it can't pump fuel into it. Plus a lot of what I have read says that by 1995 (which is the year of my pickup) the problem was fixed.
So do I have gas just disappearing, evaporating, or is it actually the cross flow problem and I just don't understand it?
Old Aug 14, 2011 | 11:34 AM
subford's Avatar
subford
Sounds like you have a hole in the rear tank and it is leaking fuel as you drive on the front tank.
Old Aug 14, 2011 | 12:43 PM
Bankrupter's Avatar
Bankrupter
Odd you bring this up. I noticed my rear tanks do the similar thing past few fill ups on my 95 and I drive it the same. front to rear.. My rear tanks also gives me way less range but its smaller then my front. I know my rear has no leaks. Also know my front vent line does. Other then the gauge reading lower, then after fill up, it has no issues. I thought it was just the way it filled being a utility body and having the inherent tube issues. Watching this thread to see what you find.
Old Aug 14, 2011 | 03:12 PM
Fordenthusiasts
A hole is actually kind of what I wanted to hear, because that means that I'm really not getting as bad of gas mileage I as thought and can be fixed. On the other hand hopefully it is repairable without having to buy a new tank.
Another thing I forgot to mention. Lately I have been smelling a strong gas odor coming from under the hood and it seems to be coming from the evaportive (charcoal?) canister. It is strong enough that you can smell it walking around the vehicle and also in the cab. It has been really hot here lately, highs 110-115 degrees, so is it possible that somehow the gas is being evaporated out through a vent line or something. I've never really looked at how the fuel system is plumbed and whether or not it could even evaporate through a vent line.
I guess in the mean time I'll burn up the gas in the rear tank and take it down to inspect it.
So it is probably not the crossfueling problem? Any more ideas?
Old Aug 15, 2011 | 08:18 AM
Fordenthusiasts
Morning bump to see if anybody else has had this issue.
Old Aug 15, 2011 | 08:28 AM
Conanski's Avatar
Conanski
That's a key piece of info that could explain your problem. Gas is stored in underground tanks where the temperature is very low compared to what it is above ground, and gas like any fluid expands with temperature. So if you completely top up your tanks there is no room left for expansion when the fuel volume heats up and it will be forced into the evaporative system. In general you should never add fuel to a tank after the automatic shutoff cuts off the pump, but especially when it's stinkin hot outside.
As for the gauges reading different... that's common and there isn't much you can do about it.. maybe change the float(level sender) inside the tank but there's no guarantee a new one will be more "accurate" in terms of tank proportions.
Old Aug 15, 2011 | 08:46 AM
Bankrupter's Avatar
Bankrupter
Even if they read past full after fill up ? I can handle this explanation... Means I have no further work to add to the ever growing list
Old Aug 15, 2011 | 07:02 PM
Fordenthusiasts
So more than likely it is expanding the fuel and sending it into the evaporative system, and not some part, like check valve or something that is wrong? Well that is good news I guess. I will start not topping it off after the automatic shutoff.
Thanks.
eds72
Jul 14, 2015 08:25 AM
nollaig
46
Jan 2, 2013 10:24 AM
droptopscot
Dec 9, 2011 10:14 PM
brucers
Oct 16, 2011 12:18 PM
Heff2727
Aug 7, 2004 09:25 PM
