E150 heater core
Old Nov 8, 2002 | 05:01 PM
billyb's Avatar
billyb
E150 heater core
Old Nov 25, 2002 | 07:15 PM
lawless's Avatar
lawless
Post E150 heater core
1989 E150 WITH A 302. Does anyone know how to replace the
heater core. thanks in advance.
Old Nov 25, 2002 | 07:59 PM
cbwarrior's Avatar
cbwarrior
There should be a panel inside on the passenger side that you take the bolts out of and after diconnecting the heater hoses under the hood, pull the core out thru the passenger compartment.
Old Nov 25, 2002 | 08:03 PM
lawless's Avatar
lawless
E150 heater core
I got the bolts on the bottom of the cover off, but
i can't get at the top ones. do i have to take the dash apart.
Old Nov 30, 2002 | 08:16 PM
samhihn's Avatar
samhihn
E150 heater core
No, you don't have to take the dash apart. On the passenger side under the dash the first panel you have to remove is a cover just put there for appearance sake. It looks like a square cake pan made out of black plastic. Then, on the left side under the dash, next to the engine cover there will be another cover that comes off with 4 screws. After removing the hoses from the engine compartment side and removig the access panel the heater core and related seal can be removed from that left side. It's held in with a metal bracket....best of luck
Old Oct 7, 2003 | 01:41 AM
Thomas Hand's Avatar
Thomas Hand
I have now been working on my core replacment for two days. I have NO panel on the left side. I had my computer that was under the black plantium but I can not get to the core. I have Fuel Injection and a 1988 or 89? I have remove the cover(decrative) and then the Computer that was under the black plastic case. But no way to get to the core. No screws on the side toward the engine compartment. I have removed the three screws on the left side which goes through the fire wall and one on the right side but I think there is one on at the top which I can NOT get to. HELP??? I'm confused..
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
