'51 F4 project
#1186
#1187
#1189
#1191
#1192
#1193
When I'm putting harnesses like that together I like to take one extra little step. Instead of using the crimp on type terminal as intended I'll take a small punch and push the terminal part out of the blue plastic insulation sleeve. Then I'll add a small piece of heat shrink onto the wires, put the wires into the crimp terminal and actuall solder them instead of crimping them. Then slide the heat shrink over it and shrink in place. When its all said and done it makes for a nice looking termination.
I'm glad you're making progress. Hopefully I have some progress to brag about on my truck soon
Bobby
#1194
I don't want to high jack ththread but it is related.
Is the heat shrink tubing sufficient for insulating or is it only for waterproofing?
How about using it in house wiring? I got a ceiling light that was original to our 1929 house. It had cloth insulation. It was not too bad in terms of fraying. It has three light sockets. I went to the local lighting supply store but they had no sockets that fit the housing. So today I put heat shrink tubes over the 6 wires to better insulate the cloth covered wire. I also used liquid tape where the wires enter the base of the socket.
Is this OK to do?
Is this OK to do?
#1195
Is this OK to do?
Is this OK to do?
#1196
#1197
Wow Joe, Fantastic work!! Nice job on refurbishing the dash lights!
Bobby
Bobby
But I totally agree with you that a soldered connection will always be better than a crimp connection, provided it's done right.
#1198
Joe,
My main reason for doing it is that I didn't like the look of the blue and/or yellow plastic jackets on each termination. It can be a little bit of a pain to push the terminal out of the plastic sleeves, yeah, I know, you can buy them without the insulated jackets but I seem to have a huge supply of the insulated one and I wasn't about to go out and buy any others....LOL. (sometimes its hard to be me.....)
Keep whittling away at it, the truck is coming along nicely
Bobby
Bobby
#1200
Our daughter and husband were visiting from VA this past week, and some of their friends were over at our place to see them. One of them, Anna, a Marine Corp major out of Camp Pendleton, wanted to see Betsy. She then wanted to go for a ride! Well, of course I had to accommodate our guest... It was dark, so I used the headlights for a change (I don't drive Betsy at night often). We just took a spin around the block, but everything worked as it should.
Anna convinced her husband that he also needed to go for a ride. He was not nearly as excited as she, but told me he'd like to someday get an old truck and rebuild it for his daughter (she's now 3 years old). He wants a Chevy, but I have a while to work on him.
