Sponsored by: Real Truck
V10 Engine Problem
Old Aug 24, 2011 | 08:36 AM
DarrellinCeres's Avatar
DarrellinCeres
Testing a pump on the bench really doesn't tell you if the pump is good or bad just that the motor runs. It needs to make enough pressure and do it with enough volume to feed all 10 injectors. I had a pump that would make static pressure but with engine running under load it would fall off. Did a volume check and the flow was low.
I’d check for a vacuum leak. It’s easy to knock a hose loose or crack one on our vintage truck while diagnosing a problem. I’ve been replacing vacuum hoses on mine lately because some of them are starting to crack and split. We have about the same truck. 99 V10 250+K miles.
Yes a motorcycle jack works great for dropping a fuel tank. I've used one for that a couple of times. Also works as a transmission jack.
Old Aug 24, 2011 | 11:24 AM
03F350XLT's Avatar
03F350XLT
Iac issues can cause all the symptoms u have as well. Truck die when rpms are dropping?
Old Aug 24, 2011 | 05:38 PM
jmosroc's Avatar
jmosroc
What is an iac? Truck doesn't die when rpm's are dropping, but sometimes I notice a lag in horsepower when accelerating.
Old Aug 24, 2011 | 05:43 PM
barthel's Avatar
barthel
Idle Air Control valve. It's on the back of the throttle body, it regulates the idle when the engine is cold.
demoman01
Modular V10 (6.8l)
33
Nov 10, 2024 07:44 PM
BigBlue2004
Aug 3, 2015 11:49 PM
makemeknowit
Modular V10 (6.8l)
18
Nov 4, 2014 03:15 PM
rdkeisman
Oct 10, 2011 08:15 PM
hmtroman1
Modular V10 (6.8l)
Mar 11, 2007 01:35 AM
