Turbo
Old Aug 13, 2011 | 09:18 AM
bubba_78363's Avatar
bubba_78363
Turbo
Quick question for the experts. Last night i was driving over one of the mountain passes here in Wa state and while headed up the turbo would spool up passed 20psi, and then it would "fart", and when it would fart rpm's would fluctuate also. It did this the entire way up. It was dark out so i could not tell if anything was coming out tailpipe as well. No engine light, no evidence of puking out bottle. Is this just an indication that the turbo needs to be cleaned or something else. Truck in question is an'05 F250 6.0 with 82k. Also I am not running tunes. So any suggestions. Thanks fellas. Matt
Old Aug 13, 2011 | 12:17 PM
bubba_78363
Any thoughts. Unloaded not towing
Old Aug 13, 2011 | 05:46 PM
BLADE35's Avatar
BLADE35
sounds lke the turbo veins are sticking and needs to be cleaned
it realy should only turbo fart if you got the acc. pedal smashed and let off quick
If yours does it randomly veins could be sticking or a bad VGT silinoid
any codes
Old Aug 13, 2011 | 09:29 PM
bubba_78363
Scangauge didn't record any. Its weird cause it would only act this way when going up steady incline all other smaller hills it works as advertised. Guess i am fixing to get up close and personal with turbo
Old Aug 13, 2011 | 09:40 PM
BLADE35's Avatar
BLADE35
were you watching Boost with SGII
Old Aug 13, 2011 | 09:50 PM
bubba_78363
I was trying to while driving, and it seemed to be above 17psi and EBP was right at 39 when it would dip down and then come right back up for about 20yds and then repeat
Muddy 13
Jun 20, 2011 06:29 AM
Joelong258
Mar 28, 2010 11:06 AM
02GrayPowerStroke
Feb 17, 2010 02:06 PM
ktplotts
May 10, 2005 12:05 PM
