3-4" dp and stacks
Old Aug 14, 2011 | 02:40 PM
jg96powerstroker's Avatar
jg96powerstroker
Originally Posted by PowerstrokeRyan
thanks guys
your best bet on your stacks is 1 are you doing 4in 5in or 6in.... than you will want your new dp..(i have a stanless dimondeye) ebay... than i would do a cat deleat..( i have 5in.. ebay) than what ever size pipe you run to hook it up.. id do 4in or 5in... but your stacks and elbows, clamps t pipe can be all got from a truck stop... t pipes are bout 150 bucks 5in elbows are 35... take 2 elbows cut the backs out weild them up and there is your t pipe...i have lots of picks as so do must guys.. but you can do it your self for bout 300/ 350... most kits are 600and up
Old Aug 14, 2011 | 02:48 PM
chicagodragon's Avatar
chicagodragon
I built my own kit for less than half of what they cost. Besides, with my tool boxes I would hav had to modify it anyway
Old Aug 14, 2011 | 03:12 PM
fordpride's Avatar
fordpride
This Travis single 6"
Old Aug 14, 2011 | 03:14 PM
chicagodragon
Mike, where did you find that old pic? The smithsonian?
Old Aug 14, 2011 | 03:46 PM
fordpride's Avatar
fordpride
Haha it took me about ten mins to find it just had to find his thread from a few month ago
Old Aug 14, 2011 | 03:56 PM
PowerstrokeRyan's Avatar
PowerstrokeRyan
i already have a 3" dp and 3" cat delete pipe. so i would just need to get some pipe to run from cat up to stack, i am only going to do one, unless you guys talk me out of it lol.
Old Aug 14, 2011 | 04:10 PM
chicagodragon
Do dual stacks!!! After you like the sound if one, you'll want two. And that will create more work. Been there done that and got the shirt. Lol
Old Aug 14, 2011 | 04:12 PM
chicagodragon
Btw, shop around fir the pipe. Some places think exhaust pipe is made out of gold
Old Aug 14, 2011 | 04:21 PM
PowerstrokeRyan
yeah, everyone says that i should do duals and i can see why, i guess the next question is, how should i go about the hole in the bed, should i make it tight or alittle bigger for room for travel. also i dont want the open metal to cause rust, live in Wisconsin so truck will see alot of salt. I plan on having the bed bedlined with line-x as well as the whole underbody and frame, when i get the chance. Uncle owns part of line-x so i would get a good deal. They told me that the line-x can be near any heat outputs, would my exhaust get over 1000*F if not i figured this way i could just line-x around the pipe hole.
Old Aug 14, 2011 | 04:31 PM
chicagodragon
Leave a little room, these trucks flex alot, besides it gives you a drain hole when you wash it out
Old Aug 14, 2011 | 05:17 PM
PowerstrokeRyan
ok, about 1/2 inch all the way around or 1"?
and will i be able to put the bedliner in as well?
Sorry for all the questions, just want to only have to do this once
Old Aug 14, 2011 | 05:20 PM
jg96powerstroker
i have 5in in the bed.. did a 6 1/2 hole. dont for get to use flex pipe from elbow going up to pipe under the bed!!! dont be a one stack wonder! lol there is a reason you dont see lots of trucks with one stack! lol
Old Aug 14, 2011 | 05:23 PM
  #28
fordpride's Avatar
fordpride
Yea you will be able to do a bed liner. Do you hole one inch bigger then your pipe. You will also want a peice of flex pipe under the truck for when the truck does flex it sant damage anything
Old Aug 14, 2011 | 05:35 PM
  #29
jg96powerstroker
Originally Posted by chicagodragon
just keep em taller than your booze
dude!!! lol that is sweet! my truck is always full of empties!!! what opitan is that?? bed full of boos! lol
Old Aug 14, 2011 | 05:46 PM
  #30
chicagodragon
...and a small pa system. I help out with local festivals and parties
