General Diesel Discussion
LCF 45 - Question!
Old Aug 12, 2011 | 05:05 PM
Jaggard's Avatar
Jaggard
LCF 45 - Question!
I have a LCF 45, 4.5L V6. My turbo charger unit is leaking oil into the air intake and out onto the top of the engine, which apparantly means a seal inside it is broken.
I've been told, by 2 different people, that when this happens you have to replace the whole unit as its near impossible to refurbish. Ford, for parts only, are quoting $2300 for each turbo charger. I'm amazed they would cost anything near this price. Apparantly its also a fairly common thing for the turbos to break/stop work on these trucks.
Is any of this true? Would appreciate any help! Thanks!
Old Aug 13, 2011 | 08:43 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE.
Haha, I first thought you were trolling here, but I looked that engine up and found it.
I've never heard any talk about that engine on FTE. I'm sure the turbos will be a dealer item only unless you could find a wrecked truck somewhere.
Good luck.
Old Aug 14, 2011 | 07:50 AM
tjc transport's Avatar
tjc transport
i ain't rite
since that engine was made by international, try asking an international truck dealership.
Old Aug 18, 2011 | 11:59 AM
Custom Plumber's Avatar
Custom Plumber
Jagarrd, sorry to hear about your problems. $4,600.0 for both turbo's?? Sounds awfully high. I have an 06 LCF 14' utlitity body 46,000 miles, so I know how you feel about getting information about these trucks.. Call some turbo shops - Evergreen Turbos, VS racing, etc and see if they can rebuuild it or send you in the right direction.
I can't offer you any help on the turbos, but I had an ongoing problem with a hard start issue the past 1 1/2 years until recently an almost no start. Turns out my front 2 port plugs in the cylinder heads had the o-rings torn and the rail ( plastic chamfered nipples ) replaced. Now the truck starts just as new << just for future reference.
Good luck,
Joe
Old Aug 19, 2011 | 12:06 AM
85e150's Avatar
85e150
I did some searching and found a long block rebuilt 4.5 for under $5500....probably didn't have the turbos on it though...but I also found this:
Turbochargers.com | Turbos, Turbo Kits, Repair, Rebuilding, & Custom Building - Turbocharger And Supercharger Repair Service
Several out there but many cater to performance or pickup market.
2003 EXCURSION
Apr 23, 2013 01:31 PM
diver110
EcoBoost (all engine sizes)
Aug 17, 2011 10:05 AM
NJTy180
Jan 3, 2007 08:43 PM
mschultz
6.4L Power Stroke Diesel
35
Jan 12, 2006 10:39 AM
lepper
Jun 1, 2004 09:27 PM
