2002 Excursion "jumping forward"
Old Aug 11, 2011 | 10:30 PM
Standardbredwoman's Avatar
Standardbredwoman
Hello
I purchased a 2002 Excursion in June. Up until now, no problem. Last week the truck started to stall out when at stop lights. Tonight when I got in I noticed the tach was going from 1 to 3 and back down then back up. I drove several blocks and stopped at a light. The truck suddendly lunged forward. It scared the heck out of me and I'm now afraid to drive it.
Any advise on what this may be? I could not find anything in the recalls that mention the Excusrion doing this. I'll have it towed to dealer. Just would like to know what I may be looking at before they take it. I really love this truck and don't want to have to part with it.
Thank you for reading.
Liz
Old Aug 11, 2011 | 10:40 PM
jh818's Avatar
jh818
What engine do you have?
Old Aug 11, 2011 | 10:48 PM
wpnaes's Avatar
wpnaes
Stalling at stoplights could be caused by a number of issues. Let us know what the dealer tells you tomorrow. Do you have the 6.8l V-10 or a diesel?
Old Aug 11, 2011 | 11:17 PM
Standardbredwoman
Thank you for your replies.
The engine is a 5.4 L V8 16 V. Automatic. It does have Cruise Control and 4 wheel drive ASB.
My apologies if this sounds ridiculous - I'm on my last 1/4 of a tank. The manual lists my tank capacity at 44 gallons. Is it at all posible that I am getting sparadic draw on the fuel pump because of low volume? I'm not really sure if that would casue the surge.
I'll let you know what the dealer has to say this weekend.
Old Aug 13, 2011 | 10:46 AM
MURDOMINO's Avatar
MURDOMINO
Honestly sounds like you might have a vacuum leak. do you hear any abnormal constant hissing noises? Your problem you are describing sounds like a the engine is actually surging, constantly trying to adjust the air fuel micture for the unmeasured extra air, causing the engine to speed up and down constantly also stalling as a result when it your coming to a stop.
Old Aug 13, 2011 | 11:10 AM
Standardbredwoman
Thank you for your reply. I will see what I can hear and see today.
Old Aug 13, 2011 | 12:53 PM
perryg114's Avatar
perryg114
Check the IAC servo and the throttle position sensor. You can put an ohm meter on the throttle position sensor (TPS) to see if it is working properly. If the sensor is bad you could get unpredictable engine speeds. The same goes with the IAC servo since it controls the air through the engine and therefore engine speed.
Pull the codes on it and see what you get.
Perry
Old Aug 13, 2011 | 08:29 PM
Standardbredwoman
My brother removed the sensor, cleaned it and the air filter. This seems to have solved the problem.
A big thank you to all who were kind enough to reply. Having guidance on what to look for sure helped us out!
Old Aug 14, 2011 | 06:19 PM
perryg114's Avatar
perryg114
Which sensor?
Perry
Old Aug 15, 2011 | 06:16 AM
1 Excursion camper's Avatar
1 Excursion camper
COP going bad? was it misfiring? when they misfire the computer will try and compensate forthe low rpm by raising the idle, and it will do it very quickly as you described!
Good luck! let us know what they find.
Old Aug 15, 2011 | 07:43 AM
jasoncw's Avatar
jasoncw
Post #8 sounds as though they fixed the issue. And it sounds like the IAC was dirty based on the reply.
my50F1
6.7L Power Stroke Diesel
32
Aug 13, 2018 10:04 PM
krmoore77
1997 - 2003 F150
18
Jan 13, 2014 03:05 PM
884x4broncoII
Oct 20, 2008 11:09 AM
FearTheDentist
26
Jun 19, 2006 10:23 PM
OJ_Bronco
Nov 18, 2004 06:26 AM
