Small Stuff
Old Aug 11, 2011 | 09:50 PM
66CustomCab's Avatar
66CustomCab
Small Stuff
I've been tinkering on my truck today & added a few small touches for fun & funtionality.
First, on the exterior. Nothing major, just a little chrome on the exhaust tips.
Next, onto the interior. A little more chrome by way of a fire extinguisher I had laying around for a few years in another dead project car.
And now under the hood. A little more chrome (I do like my chrome!), by way of an extra overflow reservoir I had rolling around the garage for a few years. I think it looks kind of nice next to the salvage yard fan shroud I installed yesterday. If you look closely at the shroud you'll see a repair I had to make with some JB weld. I'm hoping the reservoir will catch the coolant that's been spitting out of the radiator cap & causing those stains.
I hope you enjoy these little tidbits. I know I enjoy the ones you all have posted.
Old Aug 12, 2011 | 04:08 AM
Rgd9664's Avatar
Rgd9664
even with the JB it looks good, what did you get it off, i would like to get one too?
Old Aug 12, 2011 | 04:46 AM
jowilker's Avatar
jowilker
66 Your truck looks nice with the new parts. I hope the shroud works for you.
I want to say without malice that you were not listening to what your truck was telling you. It was puking coolant out of the area that it needed for expansion, and you being careful kept refilling it. These ol boys need about 3" down from the top for expansion to operate properly.
Many readers think their radiators need to be full, and think there is a problem when there isn't when it has relieved itself.
There is about 4 1/2 gallons of coolant in the system. If you can see it with the cap off, it is OK.
John
Old Aug 12, 2011 | 05:30 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
To add to what John said, Ford didn't offer a coolant recovery reservoir for F100/350's (or Bronco's) until 1980!
Old Aug 12, 2011 | 08:57 AM
66CustomCab
Thanks very much for the info, John! I didn't know, but I do now. I got the shroud off a '68 F250, Rgd.
Old Aug 12, 2011 | 01:23 PM
Customcab's Avatar
Customcab
Every thing looks great; I recommend getting a spray can of fusion paint plastic paint and once you masking tape the "Caution Fan" decal, paint the shroud and the repair would even blend in even more. Remove the shroud to paint; and then use high temp black on the radiator those expose to even make it pop even more.
Old Aug 12, 2011 | 02:19 PM
NumberDummy
The 'Caution Fan' decal has been reproduced. 1965/79 Passenger Cars used the same one as 1967/79 trucks.
One source that has it, is Dearborn Classics (dearbornclassics.com), located in Bend OR / Dearborn's Caution Fan decal part number: DF0031
Call 800-252-7427, order a free catalog. While Dearborn sells repro 1960/70's FoMoCo car parts, some are as the same as the trucks.
Old Aug 13, 2011 | 12:17 PM
66CustomCab
I may do just that. I still suspect a small leak somewhere in my radiator. My water level drops slowly over time until it gets below the baffles. Sometimes I need to add a gallon or more to the system. I'm sure overfilling contributes to this, but I'll see if the overflow reservoir addition yields any improvement before looking into radiator repair or cosmetic improvements.
martial315
Apr 25, 2019 10:10 AM
niykinick
Aug 14, 2018 07:01 AM
nikmish
28
Mar 2, 2014 08:58 PM
camodown
Jan 19, 2012 07:40 PM
08SVT
Nov 28, 2010 01:09 PM
