My journey with truck's coolant system continuos and again I need your help.
With your help I bought right radiator and water pump, new upper and lower radiator hoses and heater hoses too. I did chemical flash right before I started the replacements and by radiator instructions I did another one right after I assembled everything.
Here is the question: I used green fluid (50/50 premixed) for my coolant system and it looks very strange. It looks like something floating on top of clear water. It doesn't looks right at all. Does it mean that it's not compatible or something else? Should I do the flash again and use orange fluid?
Reason: added pictures
Dex-Cool is the biggest garbage and harm to your cooling system you can possibly do yourself. If you don't believe us, look up Dex-Cool damage on Google images.
Personally I'd flush the system out good, and go buy concentrated coolant. I always mix mine 70/30 instead of 50/50. I used this coolant flush stuff made by Prestone earlier this year, it was like $3 for a bottle of it. Worked great at cleaning all kinds of gross scale out of my system. Although this was in the summer time and I drove it with water and that cleaner in the system for a week after I put my engine back together. I'd run it for a bit with water and the cleaner and take it for a drive, dump it. Fill it again and dump it then put new coolant in it. What did the coolant look like coming out of the bottle?
What chemical did you use to clean the system?
That looks like some caustic stuff there.
Yes, I would flush again (and again)
Since there is no risk of freezing where you are just use water.
Drive it.
Flush it.
More water.
Drive it .
Flush it.
Do this until it runs clean.
Then drain the system and fill.
The premixed coolant is fine for your application, and you can be sure they use distilled/deionized water as a diluent.
I doubt there's anywhere in the continental U.S. that you would need coolant mixed for -75*.
50/50 is good to 30 below, and if it gets colder than that I don't want to think about what else is happening in my engine.
Because concentrated hydrochloric acid will eat it up and create just that kind of precipitate + explosive hydrogen gas in contact with an active metal like aluminum, zinc or magnesium.
How hard is the water in your area? I agree with the flushing method described, but I would not run it too long before you flush again and then hurry up and get the anti-freeze back in it. On your final fill if you use the concentrate, go to the grocery store and buy some distilled water for the final fill.
If that truck is local to the area, it looks like you do have a lot of minerals in your water.
