The stock turbo is capable of 25ish IIRC wouldn't want to be over that too long. My stock turbo is about the same sometimes slightly higher, depending on load.
Main reason I was asking is because I'm still trying to find out if my truck has a programmer currently installed on it. It does have a three position switch mounted to the fuse panel cover under steering wheel but it isn't plugged in to anything. The wires are just bundled together and zip tied. Therefore it had a programmer at one time but I dont know .....not knowing is bugging the crap out of me. I have decided to go with the dp custom tuner, will it matter if my truck is programmed now?
