Gas tank help
Old Aug 11, 2011 | 04:28 PM
4CFarms's Avatar
4CFarms
Gas tank help
I have a bad rear tank on my f250 and i need to replace it, is there a way to replace it with out taking the bed off? somebody please help me by possibly giving step by step directions, thanks
Luke
Old Aug 11, 2011 | 05:45 PM
madpogue's Avatar
madpogue
Remove the filler neck. Remove the straps or skid plates. The tank will drop. Reach up and remove the retainer ring and remove the assembly that holds the lines and the sender. It's a tight squeeze, but the tank will drop out.
Old Aug 11, 2011 | 07:38 PM
joe_13894's Avatar
joe_13894
Why does your diesel truck have a gas tank?
Old Aug 12, 2011 | 12:23 AM
4CFarms's Avatar
4CFarms
fuel tank... use ur head a little bit now...
Old Aug 12, 2011 | 06:50 AM
redman84's Avatar
redman84
Careful because the skid plate is what supports the whole thank. Undo it and that bad boy is free.
Old Aug 12, 2011 | 07:10 AM
DIYMechanic's Avatar
DIYMechanic
Something you may want to consider, if you're replacing the rear tank anyway is replacing it with a 38 gallon tank from a Bronco. Here is a link with the step by step directions if you're interested.
Rosewood 38 Gallon Tank Mod
Old Aug 12, 2011 | 12:48 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
Many people here said that is easy taking the bed off. Just my two cents. And yes you maybe should consider to get a bigger tank and do at the same time the fuel filler tank mod
Actually till I know that 38 gal tank isnt of the broncos: Part number F26E
Here is another link for a 40 gal fuel tank, just for info, I think the 38 gal is the best.
'05 F550 40gal fuel tank pictures from trucks photos on webshots
Old Aug 12, 2011 | 01:08 PM
Brown Falcon's Avatar
Brown Falcon
Yes, that link is good to go by. But the Broncos had a 35 gallon tank that doesn't fit well on our frames.
The 38 gallon tank is from a late 80's F350... The part number Jose gave is correct, F26E, from rockauto.com
It's worth it! I can hold 60 gallons of fuel between the two tanks now.
Old Aug 12, 2011 | 01:34 PM
DRRXR's Avatar
DRRXR
Was that a harpooned tank or ???
Old Aug 12, 2011 | 02:44 PM
Brown Falcon
Nope, not harpooned, I did the vent hose mod though. Got rid of the small inner hose on the fill neck and ran a bigger external vent hose from the roll-over valve grommet on top to the top of the filler neck.
Just had to extend the pickup tube and float rod on the 38 gallon tank. Fits perfect though, just hangs down further than stock.
Old Aug 12, 2011 | 03:40 PM
joe_13894's Avatar
joe_13894
Do you still have the spare tire under the rear tank?
Old Aug 12, 2011 | 07:42 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
Ian, you have to add the mod in your signature.
Yes its possible, see the pics how it looks like.
Old Aug 12, 2011 | 11:49 PM
Brown Falcon
I don't have mine mounted below, just sits in my bed. But there's room for it if I wanted to and still had the hardware. My old stuff was all screwed up when I bought it, and it was a dually then so I didn't need a spare.
Old Aug 13, 2011 | 09:06 PM
4CFarms's Avatar
4CFarms
are you guys sure that the 38 galon tank will fit properly without hanging tdown too far? doi need to buy a new fuel pump that goes in the tank for the 38 gal tank? and for the filler neck mod, i heard it was expensive and does it really pay off?
Old Aug 13, 2011 | 10:15 PM
madpogue's Avatar
madpogue
You don't have a fuel pump in the tank. The big tank hangs down about as far as the stock tank with the spare in place. If you're worried about angle of departure, you can put the spare in the bed.
