slave cylinder
Old Nov 22, 2002 | 02:01 PM
CrazyFordMan's Avatar
CrazyFordMan
slave cylinder
Will a slave cylinder go without any leaks?
1992 F250 r/c l/b 4X4 351 ZF5spd
Old Nov 22, 2002 | 09:17 PM
slave2dafords's Avatar
slave2dafords
slave cylinder
i would say yes. the diaphram can tear internally and cause the fluid to flow past why dont you give me/ us some more info such as symptoms and what makes you think it is the slave cylinder
Old Nov 22, 2002 | 10:58 PM
CrazyFordMan
slave cylinder
well me and a friend were out 4byin when i got stuck in a real nasty hole so i got out and hooked up my winch when i got back in the truck it would not go into gear it would just grind. so i pulled the truck out of the hole with my trusty side kick "warn" when i gopt it out i bled the clutch and it worked............for like 3 gear changes and then it was back to no clutch i looked around and there was no leaks anywhere. thats why i was asking if a slave could go with no leaks.
Old Nov 22, 2002 | 11:28 PM
heathdaily's Avatar
heathdaily
slave cylinder
It doesn't take much of a leak to kill it. Chances are the fluid is being held in the bellhousing area still. Or you could just have air getting in somehow. That'll jam up the works in a hurry.
Old Nov 22, 2002 | 11:37 PM
CrazyFordMan
slave cylinder
I took the rubber inspection plug out and still no sign of leakage
1992 F250 r/c l/b 4X4 351 ZF5spd 33" BFG Allterrains
Old Nov 23, 2002 | 12:14 AM
slave2dafords
slave cylinder
well i dont want you to "shotgun" it it seems strange that it worked fine up to the point that you got stuck but if it worked once you bled it (be it only 3 times) i would say throw 25 bucks at it. look at your hose really close pin hole leak and you will have the same trouble with the new one. let me know what you find out plz. interested in the out come
Old Nov 23, 2002 | 08:41 AM
Lightning2Fast's Avatar
Lightning2Fast
slave cylinder
i had this exact problem in a 95 f series this week at work...i would bleed the clutch...it would be fine...let it sit for a little while and then no clutch...i ended up removing the master cylinder to bench bleed it and i found the seal where the pushrod goes was seeping fluid past it and letting small maounts of air in..i put a master in it and it was good.
Old Nov 24, 2002 | 12:00 PM
CrazyFordMan
slave cylinder
well i put a new master in and it worked ( not perfect) for one day and now its back to the same old thing should i try bleeding it again?( what a pain in the a$$) or do you think it is the slave even though it is still bone dry
Old Nov 24, 2002 | 03:11 PM
Lightning2Fast
slave cylinder
did you bench bleed the master before you installed it?
Old Nov 24, 2002 | 03:26 PM
CrazyFordMan
slave cylinder
proberly a stupid question but how do you bench bleed the master?1992 F250 r/c l/b 4X4 351 ZF5spd 33" BFG Allterrains
Old Nov 25, 2002 | 11:48 AM
CrazyFordMan
slave cylinder
Anyone?
Old Nov 25, 2002 | 11:54 AM
slave2dafords
slave cylinder
clamp it in a vice put the tube coming off into a dish of brake fluid fill the resevor and with a philips head screwdriver push the piston in and let out keep doing this till there is no air coming out of the tube in the dish. once done with that put on and then bleed the slave cyl..
Old Nov 25, 2002 | 05:59 PM
CrazyFordMan
slave cylinder
well i went under to disconnect the tube from slave and i noticed that the slave cylinder is now leaking. so tommorow out comes the tranny i guess
Old Nov 25, 2002 | 07:41 PM
slave2dafords
slave cylinder
i might be totally off my fruking rocker but since when did the trans have to come out to replace the slave cyl. ??????? is it not external maybe i am wrong someone shed some light on this for me. i had a 84 250 that the slave just un bolted from. if i am wrong let it be known i dont want to be throwing misinformation around.
Old Nov 26, 2002 | 06:20 AM
Lightning2Fast
slave cylinder
the newer slaves are internal...they bolt to the inside of the bellhousing. the throwout bearing and slave are all one piece. the rangers are this way also.
