4.6 getting stuck
Old Aug 10, 2011 | 10:39 AM
F250saleen's Avatar
F250saleen
4.6 getting stuck
Hi im swapping engines and i got a donor 4.6 for my vehicle. But my only concern was that i was spinning the engine and it suddenly got stuck and would not budge rotating it clockwise. I rotated it counter clockwise and then clockwise and it was good. I checked the the rods and no play in the bearings my thoughts is that maybe the rings had grime or the timing chain binded. Any ideas the engine i got had a couple of spark plugs out so maybe some dirt got in. You think ill be good or should i get another engine? Thanks lmk
Old Aug 10, 2011 | 02:07 PM
85e150's Avatar
85e150
JMO but I wouldn't install that engine until I'd gone into it and found the problem.
Again, jmo, I wouldn't install a used engine without going through it UNLESS I could hear and see it run before the swap.
Good luck with your swap.
Old Aug 10, 2011 | 02:18 PM
F250saleen's Avatar
F250saleen
I squirted some wd-40 down the cylinders and have not had problems again, but i still have thoughts of that. The engine is super clean on the inside no sludge wathsoever. Anyone else?
Old Aug 24, 2011 | 02:08 AM
jayton4's Avatar
jayton4
I have heard old engine-folklore that says using a product called "Mystery Oil" on an engine that has sat for a period of time will help it get moving again. They say pour it right in the spark plug wells on top of the pistons.
I suspect most lubricants would help dry cylinders/pistons.
funjohnny
1997 - 2003 F150
Jan 1, 2011 05:19 PM
Michael.hoover7
1997 - 2003 F150
Dec 31, 2010 10:04 PM
coletrain777
Modular V8 (4.6L, 5.4L)
Oct 15, 2010 10:11 PM
monster4x4
Florida Chapter
Oct 23, 2008 08:31 PM
