Sponsored by: Real Truck
Oil Consumption Question
Old Jan 16, 2011 | 08:13 PM
Argess's Avatar
Argess
The only vehicle I ever bought "new" is my 1999 Ford F250SD, 4WD with manual locking hubs and a 5-speed transmission.
It's only got about 65,000 miles on it now, but it uses oil. No more now than it ever did. So even from new, this engine used oil. I probably have to add a quart every 1500 miles or so. Not really sure, as I havn't kept records.
There's no leaks, no smoke in exhaust, or anything. I'm not even very concerned, just curious.
Is this normal for the 5.4 liter engine?
Old Jan 16, 2011 | 08:15 PM
lllateralus's Avatar
lllateralus
I don't think there is anything to worry about if it has done it since new, but I do not think it is really NORMAL for the 5.4.
I had a 1999 Expedition with the 5.4 and with 120K miles, it did not use any oil between 5K mile intervals.
Old Jan 16, 2011 | 08:39 PM
foster2004f250's Avatar
foster2004f250
My 5.4 uses about a quart over 5000km, Im not worried either, just keep an eye on it!
Old Jan 16, 2011 | 08:50 PM
jimschevey's Avatar
jimschevey
i have a 2002 with the 5.4. it uses a qwurt in between oil changes (3000 miles)
Old Jan 16, 2011 | 08:52 PM
Argess's Avatar
Argess
Yes, I was trying to use miles and US quarts, but I think I am getting close to having about 5000 km on it since the last oil change,...at least 4000 km anyway.
And it was down about 1.5 litres, which is embarassing as I usually check it more often and add oil once it needs about 1/2 a litre.
Probably just a bad combination of parts using extremes of various tolerance limits.
i.e. blow-by taking saome oil out the PCV and back into the intake.
Old Jan 16, 2011 | 08:56 PM
Argess's Avatar
Argess
Jim....your post must have appeared while I was typing my last reply.
It's sort of of starting to look like my oil consumption isn't unique.
Old Jan 16, 2011 | 09:01 PM
foster2004f250
My truck is an 04, My brothers 02 does the same thing, Im not very easy on my truck, but I take good care of it, Maybe its just a 2v thing?
Old Jan 16, 2011 | 09:15 PM
scottdak's Avatar
scottdak
oil usage
I have a 04 250 with a 5.4 and I also use oil never kept track of milage. Also no leaks or burning oil, I bought it in 05 with 8000 on it and it always used oil.
