I am new here
Old Aug 9, 2011 | 08:24 PM
ford, excursion's Avatar
ford, excursion
I am new here
I am new here to this site & dont kow if anyone has asked this but here goes, I have a 2000 excursion, 7.3, it just quit running so i got out & found from the front to the rear full of oil(even up the back window). Looking under thr hood the top of the engine from the front to back was coverd. 1st-is there a low oil cut out switch or low oil presure switch that could have blown plus not let it start even after i filled the oil up then 2nd what about the injector pump seal?, thanks for all the help
Old Aug 9, 2011 | 08:51 PM
Stewart_H's Avatar
Stewart_H
You might have blown a line or seal off of your HPOP.
First thing you need to do is clean everything up and determine where the oil is coming from.
I'll send Tor (the moderator for this forum) a PM and ask him to move this to the 7.3L forum.
Stewart
Old Aug 9, 2011 | 09:00 PM
william_04_x's Avatar
william_04_x
Welcome to the forum. There are plenty of cool people here willing to help you out.
Old Aug 9, 2011 | 09:12 PM
joetech's Avatar
joetech
The seals leak on the HPOP often if I remember correctly it is an easy fix only 3 or 4 seals
Old Aug 9, 2011 | 09:25 PM
ford, excursion
ok thanks but if the seals r leaking will that also cause the engine to just die & now not start?
Old Aug 9, 2011 | 10:06 PM
Stewart_H's Avatar
Stewart_H
The injectors are oil driven, so a lack of oil theoretically will keep the engine from running.
You can also have other problems keeping the engine from running, like an ICP going bad, or the fuel bowl heater shorting out, fuel pump giving up the ghost, or so many other reasons.
Where are you located?
Stewart
Old Aug 9, 2011 | 10:18 PM
ford, excursion
i am by tulsa oklahoma, thanks for all the help, just to let you know, it ran fine till the oil leak driveing home from work, i was driveing when just lost all throttle so i costed to the side, it cranks good just wont start up & the top of the engine is full of oil, i did see some dripping by the injector pump but it is to dirty, my flash lite was weak, it was to hot & it wouldnt start to realy see where it was comeing from...lol
Old Aug 10, 2011 | 05:52 AM
njneer1's Avatar
njneer1
It is likely the oring on the rear plug of the HPOP.......this happened to mine....you can get orings from guzzle at diesel orings......don't run it out of oil.....it doesn't take long to dump gallons
Welcome to guzzle's Ford PSD Web Pages
Welcome by the way
Old Aug 10, 2011 | 08:51 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Moved per Stewart's request to get you some better answers...
Old Aug 10, 2011 | 09:54 AM
Tailgate77478's Avatar
Tailgate77478
Welcome!
As mentioned, it is likely a HPOP seal. I changed the oil this weekend in one of my Excursions, and sucked out about 3/4 of a quart of oil from my HPOP reservoir as well. Well, like a doofus, I forgot to put oil back in the HPOP. The engine fired up, ran about 2 seconds, and died immediately. I immediately realized what happened, dumped a quart of oil in the HPOP reservoir, and it fired right back up.
Old Aug 10, 2011 | 10:27 AM
Rose Clifford's Avatar
Rose Clifford
Sounds like you HPOP is leaking and has dumped enough oil for your injectors to stop working. I bet if you seal the HPOP up (and replace your non-serviceable plug while youre at it) you wont see any HPOP problems for a long long time.
Was it a sudden leak, or has it been dripping for a while? Do you have spots on the ground where you park?
When my HPOP was leaking, I pressure washed it and then stuffed paper towels around it and felt around every hose/plug with a qtip while it was running until I found where the oil is coming from...mine was just a drip so it was a little harder to find, it sounds like yours is slightly more drastic...
Let us know what you find, this shouldnt be too hard to fix.
Replacement O-rings for Ford Diesel Engines
Old Aug 10, 2011 | 01:29 PM
Brother Les's Avatar
Brother Les
Welcome to the forum. It looks like you have been given some good advice. Please let us know what you find.
Old Aug 10, 2011 | 01:34 PM
1996pwrstrk's Avatar
1996pwrstrk
Welcome I agree I believe the HPOP-( high pressure oil pump ) o-rings to be your problem you will probably need a mirror and flash-light to locate the leak . I had one let go and I had a trail of oil from my dad's house to mine 13 miles. Don't hesitate to ask any questions fire away that's what were her for. Do you know where the HPOP is ? When these 7.3 get to low on oil they just shut down so you must be really low in the crankcase and in the HPOP.
Old Aug 10, 2011 | 05:36 PM
ford, excursion
thanks for all the help, i am going to get some cleaner to clean it & check for were the leak is. I have worked on alot of big gens with all types of diesels, but never mine, go figure. anyways i hope that is all it is, it did dump over 1 gallon of oil but i filled it back up but it still didnt start, i didnt fill the res back up so i am sure that had aomething to do with it. I will check & fix the leak & get back, thanks again
Old Aug 10, 2011 | 05:39 PM
ford, excursion
hey one more thing, does anyone have a good site that has a good schematic of the pump i can look at?
