Thanks guys, that is what I was hoping the the 10000 lb package was, but of course noone at the dealership knew anything about it. The truck has been on order for about a month now. I ordered an 11 in May but that was the one that got hit in the dealer lot on the weekend of the 4th. Bashed in the drivers side bed, cab and doors. Looked to be about 10k in damage so we ordered a 12 I would still like to know what happened to it.
I believe my truck has the 10k package. That is just the vehicle capacity on the 4 tires attached to it, right? Would the GCWR still be the full capacity (truck + trailer)?
The GCVWR is driven (pun intended) by your drive train and your towing package. Here are the 2012 numbers (which should be the same as the 2011 numbers):
If you use wheel chocks on the trailer, you will never have the escaping truck problem again. Most of the G rated trailer tires are made in China and not much safer than what you have probably. I think Goodyear may make a G rated trailer tire, not sure on that.
i have an excel 5er and it has the goodyear g rated tires on tandem axles
They weren't always rated that way though. Here's from the 2011 Diesel Supplement:
The Job1 350 DRW trucks are rated at 29,000, Job 2 DRW's gained an extra 1k to 30,000 with the help of an extra cross member on the frame in the middle of the bed area.
Just to clarify the upgraded GCVWR for the Job 2 build, the center cross member was upgraded to a higher tensile strength steel. There was not an additional cross member added.
I feel like I might be nit picking here but I did not want Job 1 owners trying to find their missing cross members...
