Sponsored by: Real Truck
Power Lock Problem
Old Apr 1, 2003 | 07:59 PM
jfremder's Avatar
jfremder
Power Lock Problem
My 1999 V10 E350 SD has a problem.
The power locks work perfectly from the RKE key fob, and the door switches all will LOCK just fine.
The Problem is I can only UNLOCK from the RKE Key Fob (Ignition off of course) Or I can UNLOCK manually. I can't unlock from any of the door switches, even though the LOCK function from the door switches works just fine.
Any idea's? Tried reprogramming module, jiggling wires in the door jamb, no luck.
Maybe my truck just wants me to stay longer
Any Ideas?
Jeff
Locked in, in Milwaukee WI
Old Apr 2, 2003 | 06:22 PM
jfremder's Avatar
jfremder
Power Lock Problem
Update-
Pulled and checked all the door switches, have ~11.5V on the lock side, but only ~5.5V on the unlock side.
All the door wiring harnesses seem intact. Tried a replacement switch at all locations to no avail...
Where is the module that controls the lock/unlock functions from the RKE located?
Old Apr 2, 2003 | 10:06 PM
02superstroker's Avatar
02superstroker
Power Lock Problem
if i understand what you are saying.. the door lock/unlock switch inside on the door does not do the job? does it try and make noise at all? if so i had the same problem.. was the lock actuator. dealer fixed no prob, not expensive.. good luck
Old Apr 2, 2003 | 10:54 PM
psd tech's Avatar
psd tech
Power Lock Problem
Check for a broken wire in the rubber tube between the body and the door on the drivers door.
Old Apr 3, 2003 | 06:21 AM
jfremder's Avatar
jfremder
Power Lock Problem
Actuators are fine, it works perfectly from the key fob. Just won't unlock from any of the door switches.
Already checked the wiring through all the door jambs...
roughneck101
May 13, 2016 08:09 AM
detill
Aug 29, 2013 06:23 AM
TwoMuchMud
Escape & Escape Hybrid
Oct 11, 2011 11:00 PM
jonboy88
20
Jun 12, 2006 03:35 PM
K2JJB
Electrical Systems/Wiring
Jun 15, 2004 11:05 PM
