Melted Battery Post!!
Old Aug 9, 2011 | 12:19 PM
jbpowers's Avatar
jbpowers
Question Melted Battery Post!!
Yesterday I was driving my Expo on some pretty rough pavement. I was taking it slow, but something clearly shifted around, and I started to see smoke coming from under the hood near the battery. I popped the hood, and the negative terminal was completely melted into a puddle of lead, and the negative cable was arcing juice to a small piece of post that hadn't yet melted. I grabbed a stick and moved the neg. cable to a safe(r) place.
When I tried to sub in a secondary battery, as soon as the second post is connected, the negative post starts smoking and melting again.
I clearly have some ground wires exposed and touching the frame someplace (seems the most logical place to start to me).
Any advice here would be very welcome, but in particular, methods to trouble shoot using a volt meter. I used one last night connecting pos to pos, neg to neg, onto the battery cables only, I didn't even have a battery in at the time. When I turn on the 1000 amp setting, it would register it on the meter. This suggests to me that there is a closed loop all the way from my pos. terminal to the negative.
Now, with the battery out, and the keys all the way off and out, I should not be able to send a charge from one set of terminal wires to another (pos to neg for example) should I? That loop should not close until I turn the key in the ignition correct?
Sorry for the mini-novel. Any help would be so gratefully accepted!
Old Aug 9, 2011 | 12:56 PM
Bluegrass 7's Avatar
Bluegrass 7
Follow the positive cable it's full length to see where the insulation has worn through.
It's not the negitive side because it's already the grounded side to the engine block and the frame.
Voltmeter is not much help on this fault.
Good luck.
Old Aug 9, 2011 | 01:38 PM
LxMan1's Avatar
LxMan1
Moved to correct forum.
Old Aug 9, 2011 | 10:33 PM
jbpowers's Avatar
jbpowers
Good luck.
Thanks, I definitely will. I ran out of time today, we'll take a close look at her tomorrow.
Old Aug 10, 2011 | 01:14 PM
kailor's Avatar
kailor
Make sure the braided grounding strap is properly secured to the frame. Many times the braided grounding strap terminates at/on the firewall.
Old Aug 12, 2011 | 11:31 AM
kailor's Avatar
kailor
Did you figure out the problem? Please share.
dmbrenneman
2009 - 2014 F150
20
Mar 9, 2025 02:58 PM
88dually
Jul 21, 2014 03:38 PM
oldworldwil
Nov 16, 2012 07:02 AM
cagey63
Aug 9, 2011 12:29 PM
DeepDoc1
Dec 12, 2006 04:57 AM
