Air intake mod help
Old Aug 9, 2011 | 11:51 AM
cowboyfordlord's Avatar
cowboyfordlord
Air intake mod help
If any of you have pics of the air intake mods you have done to your 7.3s I would appreciate seeing them. I am trying to get ideas for making one on my truck which is the early '99.
Thanks for any help.
Old Aug 9, 2011 | 11:56 AM
riverrat41's Avatar
riverrat41
If you can find a K&N filter tube it works great.....Just leave the actual k&n filter off and put the 6637 on.
Old Aug 9, 2011 | 01:05 PM
bkgeig's Avatar
bkgeig
I put in a 6.0. Check my posts for a description.
Old Aug 9, 2011 | 01:22 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Here is my 6637.
Old Aug 9, 2011 | 01:51 PM
Rose Clifford's Avatar
Rose Clifford
I've since shimmed it up with some styrofoam blocks to keep it from wearing through MORE. just make sure the air filter is not in contact with anything when youre done
<a href="http://s1141.photobucket.com/albums/n583/RoseClifford/Truck/?action=view&amp;current=6637Installed.jpg" target="_blank"><img src="http://i1141.photobucket.com/albums/n583/RoseClifford/Truck/6637Installed.jpg" border="0" alt="Photobucket"></a>
Old Aug 9, 2011 | 02:25 PM
cowboyfordlord
Thanks for the info and pics. How big is the outlet on the 6637 is it 4" like the stock intake outlet?
Old Aug 9, 2011 | 02:36 PM
cowboyfordlord
Miller_feed:
Where did you get the piece that goes between the turbo and the rest of the hose? It looks like it maybe says S.S.A. on it. Thanks.
Old Aug 9, 2011 | 02:53 PM
miller_feed
Yes, 4"
Miller_feed:
At the time I took this pic (I can't find my newer pics) I used a 3" DWV-PVC coulping to attach the filter to the intake tube. I now have a piece of 4" exhaust pipe in the place of the coupling.
On the intake tube that attaches to the turbo says USA on it. I have a TN BB turbo (aftermarket) that has a bigger inlet then a stock turbo.
Old Aug 9, 2011 | 02:55 PM
miller_feed
This pic is with the cover on the 6637.
<CENTER itxtNodeId="45" itxtHarvested="0"></CENTER>
Old Aug 9, 2011 | 03:18 PM
cowboyfordlord
Thanks for the info and pics. I have to replace my turbo inlet tube(cracked) is why I was asking about that. Do you know the inlet size for the stock turbo on the newer '99 and up? Was thinking about upgrading to that hose if it will fit. Mine is 3" on the early'99. Hopefully I can do a cold air intake mod/system soon.
Old Aug 9, 2011 | 03:26 PM
miller_feed
The stock turbo is like yours, 3" while the TN and GPR are 4". Clay (RIFFRAFF DIESEL PERFORMANCE) can set you up with everything you will need to turn your e99 to a late '99.
Old Aug 9, 2011 | 03:29 PM
cowboyfordlord
Okay thanks. I left a phone message with Clay about 30 min ago. I had bought injector cups, rings, and rented tool from him recently and found the air tube problem when doing that job.
Old Aug 9, 2011 | 03:48 PM
miller_feed
Cool deal. Let us know what you decide.
4X4 IN REFUGIO
6.4L Power Stroke Diesel
May 11, 2012 05:09 AM
1978Crew
Aug 27, 2011 12:00 AM
1978Crew
Aug 26, 2011 11:45 AM
scraig310
1997 - 2003 F150
Nov 14, 2009 09:32 AM
