1987 F-150 4X4 I-6 4 speed granny short box.i went to the woods to scout new area. everything fine. on the way home hit a big bump and the truck shut off. it will turn over but not start. i checked the inertia switch and not tripped. fuel pump on frame works and sounds like the tank pump works too.(i listened as someone turned key.) we towed it home and now it sits.what should i check to find the problem? thanks for the help.
