1990 7.3 no fuel to injectors
I have owned a 1990 f-superduty (169,000 miles) for 3 good years and it has started having hard start issues like air was entering somewhere. It would crank/run fine and then not start at all until air was bled out.I decided not to get stranded again until the problem is identified and fixed. I put a return line kit on it and new glow plugs as 2 plugs were bad. Still no start and it seemed to be cranking kinda slow so 2 new batteries and a starter installed. Cranks fast enough now, getting fuel to fuel filter and out of bleeder valve on canister while cranking. While cranking,it has little fuel to some injector lines/none on others. It has voltage to the fuel shut off solenoid, but it is not a definitive "click" but a quiet noise. There is no voltage to the fast idle solenoid. Any ideas or test procedures appreciated.
1990f-superduty
Aug 9, 2011 12:47 AM
94ATSIDI
Jan 25, 2011 01:03 PM
MyMoneyPit
13
Nov 19, 2009 01:12 PM
