Ok, my truck a/c only blows cold when it is not extremely hot out like early in the am and late in the evening, other than that 60-65 deg is all I get. My compressor clutch gap is good and compressor is cycling about every 5 sec. Cleaned coil 2 weeks ago, it wasnt bad at all. Put gauges on today and with outside temp at 90 i got 38 on the low side and 150 on the high side. Installed a heater core bypass not too long ago . Going to check the evap coil tommorrow. Is there anything else I,m missing and whats next? Vac system down and re charge?
If your compressor is cycling every 5 secs you are low on Freon.
You neecd to add freon to get low side up to 40-45 on low side.
High side will probably get to 250-275
Tried adding freon too, It dosn't seem to want to take any. I let it cycly for a while then open up the low side and let it cycle a few times with valves open and almost no change in pressur on the low side or the high side.
my a/c didnt work until i fussed with the plugs on the compressor under the hood. i guess one shook itself loose...i figured id wiggle them around before slimming my shims down and voila!
OK jumped the low side switch and got the system to toke about 10 oz of freon over the course of about an hour and a half. I jumped the switch, let the system take some freon, plug the switch back in and let it cycle for a few min then repeat. Absolutly no change in either pressure. Still about 35 on the low side and 145-150 on the high side. And no change in temp coming from the vents still 60 ish (didnt have my temp gauge with me) Also took the fan out and hosed off the condensor coil off it wasnt that dirty.
